Old 08-18-2020, 10:31 AM   #1 (permalink)
What Happens When Hope Takes Over Planning
https://www.breitbart.com/environmen...-energy-flaws/
Old 08-18-2020, 12:52 PM   #2 (permalink)
I guess the plan is to store additional gigawatt hours in battery storage. That only works if you have additional gigawatt hours that can't be used.
They shouldn't have shutdown their nuclear power plant.
I say it's what happens when political science majors and social justice warriors make engineering decisions.
Old 08-18-2020, 02:00 PM   #3 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
I say it it's what happens when political science majors and social justice warriors make engineering decisions.
Agreed, backbone power like nuclear needs a larger piece of the pie and going forward 50-100 Years will be the only reasonable priced energy source. Peaking plants are definitely needed but they want them gone as well
The will power to improve nuclear is a need but we keep messing with large energy wasters and pie in the sky.
Too bad so sad, have fun with half days of power
Old 08-18-2020, 04:49 PM   #4 (permalink)
Solar normally works great for peaking. But you have to be prepared for unusual circumstances or the only possible outcome is blackouts.
I say put solar on homes, it blocks some of the sun off the homes roof too.
I think any large scale solar should be put on roof tops first, give the power to the people.
Old 08-18-2020, 08:19 PM   #5 (permalink)
Does anyone remember when we agreed that people should install solar water heaters before solar panels?
Fat Charlie (08-20-2020)
Old 08-19-2020, 12:57 AM   #6 (permalink)
That's when panels were $3 or $4 a watt.
I'm actually watching a few different solar water heater setups on evilbay and I will probably pick one soon.
No one thought premium PV panels would be made in the USA for under $1 per watt.
In at least some municipalities you can do solar water heating and you won't have to get engineering plans approved by the state and inspected. It's pretty easy to DIY some plumbing.
Last edited by oil pan 4; 08-19-2020 at 01:55 PM.. Reason: I'm going to tag this thread, you know what I'm going to tag it with. You shouldn't even need to look.
Old 08-19-2020, 01:12 AM   #7 (permalink)
Oh if you use math, reason, and logic you will be hated."--OilPan4
Power generation is definitely one of those things where if you do it well you're the bad guy.
Old 08-19-2020, 12:47 PM   #8 (permalink)
rmay635703's Avatar
No but logically solar heat is more efficient than photovoltaic
The Following User Says Thank You to rmay635703 For This Useful Post:
Old 08-20-2020, 02:34 AM   #9 (permalink)
Generation and distribution are legitimate concerns. But it's rubber-meet-road at the point of use. If geodesic dome houses had become the norm in the 1970s the housing stock would be largely converted. The total requirement would be somewhat less. 50%? 10%?
Just having a wind powered ventilation system is a start. Space and water heating. An electrical microgrid if in a Democrat-run state.
Old 08-20-2020, 04:51 AM   #10 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
The duck curve:
Now how to shift energy from noon to evening, or demand from evening to noon?
Energy for hot water can just be stored in the form of hot water. Cooking on the other hand need too high temperatures for that, maybe hydrogen is the solution here, the beauty of using it for cooking is that you don't need an expensive fuel-cell like when using it for electricity storage. And since you don't need small tanks like in a car, lower pressures can be used and a lot of the waste with compression can be avoided.
And the McMansions with low thermal mass, black roofs and huge interior spaces? Perhaps it's time to admit that they were a daft idea all along. We instead need houses with less interior space, with more thermal mass, that are white and even mirrory from all the angles that the sun sees them, that are more connected to nature - and by nature I mean all the free thermal mass of the ground.
The Following User Says Thank You to jakobnev For This Useful Post:
freebeard (08-20-2020)
lies, scam
