What Happens When Hope Takes Over Planning
I guess the plan is to store additional gigawatt hours in battery storage. That only works if you have additional gigawatt hours that can't be used.
They shouldn't have shutdown their nuclear power plant. I say it's what happens when political science majors and social justice warriors make engineering decisions. |
The will power to improve nuclear is a need but we keep messing with large energy wasters and pie in the sky. Too bad so sad, have fun with half days of power |
Solar normally works great for peaking. But you have to be prepared for unusual circumstances or the only possible outcome is blackouts.
I say put solar on homes, it blocks some of the sun off the homes roof too. I think any large scale solar should be put on roof tops first, give the power to the people. |
Does anyone remember when we agreed that people should install solar water heaters before solar panels?
That's when panels were $3 or $4 a watt.
I'm actually watching a few different solar water heater setups on evilbay and I will probably pick one soon. No one thought premium PV panels would be made in the USA for under $1 per watt. In at least some municipalities you can do solar water heating and you won't have to get engineering plans approved by the state and inspected. It's pretty easy to DIY some plumbing. |
Just having a wind powered ventilation system is a start. Space and water heating. An electrical microgrid if in a Democrat-run state. |
The duck curve:
https://www.youtube.com/watch?v=YYLzss58CLs Now how to shift energy from noon to evening, or demand from evening to noon? Energy for hot water can just be stored in the form of hot water. Cooking on the other hand need too high temperatures for that, maybe hydrogen is the solution here, the beauty of using it for cooking is that you don't need an expensive fuel-cell like when using it for electricity storage. And since you don't need small tanks like in a car, lower pressures can be used and a lot of the waste with compression can be avoided. And the McMansions with low thermal mass, black roofs and huge interior spaces? Perhaps it's time to admit that they were a daft idea all along. We instead need houses with less interior space, with more thermal mass, that are white and even mirrory from all the angles that the sun sees them, that are more connected to nature - and by nature I mean all the free thermal mass of the ground. |
