Old 05-19-2009, 03:35 PM   #41 (permalink)
Hydrogen Nut
Ptero's Avatar
Smart Car ForTwo Pure - '08 Smart Fortwo Pure stripped
90 day: 51.35 mpg (US)
BMW 750iL V12 - '90 BMW V12
90 day: 26.4 mpg (US)
Wildfire 250C - '08 Shandong Pioneer 250C
It depends on your type of automatic. Some pumps are driven by the engine, others by the wheels. A friend of mine burned up his high ratio gears by coasting 5 miles, once, so it's good to know for sure which you have. The dealer should know. But my experience with people who coast automatics has always been that they NEVER know.
Old 05-19-2009, 03:38 PM   #42 (permalink)
EcoModding Punk
LeanBurninating's Avatar
Honduh Power - '98 Honda Civic HX
90 day: 44.37 mpg (US)
but when your coasting the wheels are still turning the output shaft of the tranny... even if the engine is off....
Old 05-19-2009, 04:10 PM   #43 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
The information is easily found in the owner's manual.
Old 05-19-2009, 06:56 PM   #44 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Ptero -
Our rule of thumb is that if the automatic can be flat-towed (i.e. Winnebago scout-ship), it's good to go.
[EDIT: LeanBurninating corrects me below. I read the post without reading the previous post]
CarloSW2
American Solar Energy Society
Old 05-19-2009, 06:59 PM   #45 (permalink)
EcoModding Punk
Originally Posted by Ptero View Post
COASTING IN NEUTRAL WITH AUTOMATIC TRANSMISSIONS
Never do this. Always "coast" in drive. If you have been doing this in a car that the manual does not specifically say can be "flat towed," you should sell your car.
Im pretty sure that is exactly what he said.
Old 05-21-2009, 12:51 AM   #46 (permalink)
On a commute how much is coasting?
I see all kinds of opinions on coasting in neutral or in gear but no real data for the bystandard . I realize a lot of people come to some conclusion with their own data and testing but do not share the data only the opinion. I figured I would measure how much I coast on a 6.5 mile commute. the answer is .8 miles. For me coasting in gear is the better option. In gear for the .8 miles I burn 0 fuel but if I use neutral for the same distance .4 miles I burn ~.55 gallons per hr. and for the remaining .4 miles I burn .16 Gallons per hr. Though it is not much over all, it makes better sense for me to use the 5th gear and not neutral. I do not drive on the Highway or the Freeway, it is all ~20 to 45 mph back roads.
I’m curious how much those that choose neutral or in gear actually coast and what kind of commute it is??
Old 05-21-2009, 08:58 AM   #47 (permalink)
Hypermiler
Wagons
I coast at least 5, maybe 6 miles of my 10 mile commute. Leaving it in gear would cut that in half, and require 2-3 more miles of engine running time. That would cost a fair chunk of fuel.
Old 05-21-2009, 10:02 AM   #48 (permalink)
Wildfire - '96 Ford Bronco XL
90 day: 14.88 mpg (US)
Blackford - '96 Ford Bronco XLT
90 day: 20.26 mpg (US)
Y2k - '00 Honda Insight
Gen-1 Insights
90 day: 73.98 mpg (US)
Redford V10 - '01 Ford F250 Lariat
90 day: 15.64 mpg (US)
FireFly - '00 Honda Insight DX
90 day: 69.43 mpg (US)
LittleRed - '00 Honda Insight
Flat-towing means engine off and all 4 wheels on the ground while being towed. Most all automatics can't be flat-towed without modification (such as driveshaft disconnects). With the engine running and all 4 wheels on the ground, then automatics can be flat-towed in neutral - although you'd want someone in the car to make sure it didn't kick into drive, etc.
PaleMelanesian - I'm with you on that. My pulse and glides would be a joke.
Old 05-21-2009, 11:55 AM   #49 (permalink)
Hydrogen Nut
Ptero's Avatar
Using a dash-mounted cumulative sum calculator, I kept a running total of coasting miles on a 2000 mile highway trip. Although I did not pulse and glide, I coasted every downhill from 60 down to 45 or so, depending on traffic, and was amazed to find my coasting miles totalled nearly 400 - or 20%. A better way to record this would be to link odometer output to the neutral light, then pulse and glide would be recorded and the driver would not be distracted.
Old 05-21-2009, 10:58 PM   #50 (permalink)
That really is amazing! I'm going to do more comparisons with in gear vs neutral 35mph to 15mph coast downs. What kind of commute is this 65mph Zones and is it total or 1 way?
Coasting in gear vs. neutral (fuel cut feature) WTFM8 Hypermiling / EcoDriver's Ed 28 05-29-2011 10:39 AM
Does coasting in neutral or coasting in gear save more gas? xbUser Hypermiling / EcoDriver's Ed 19 10-19-2008 01:28 PM
Coasting in Neutral... what if you can't come to a full stop after? Sean T. Hypermiling / EcoDriver's Ed 16 10-08-2008 12:11 PM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
Neutral coasting vs In-Gear coasting Netherby Hypermiling / EcoDriver's Ed 1 06-13-2008 11:53 AM
