Old 10-08-2023, 06:33 PM   #1 (permalink)
Computer-aided drafting, cardboard-aided drafting, and freaking lasers!
Bob wanted to make a giant Optimus Prime head, as one does, but wanted to actually wear it, because who wouldn't?
So, he modeled it, and used a freaking laser to cut out the carboard, and then crafted a true work of art:
Old 10-08-2023, 07:43 PM   #2 (permalink)
So much wrong with this. I only made it to 8:06.
The software -- 2016 calling...
Get Your License Key
Pepakura Designer. one-time purchase for lifetime license. $ 49.0 +tax. ADD TO
Any UV unwrapper will produce the net. Blender (Free and Open Source) can even add tabs and slots.
https://docs.blender.org/manual/en/l...per_model.html
Paper Model
Reference
Category
Import-Export
Menu
File ‣ Export ‣ Paper Model (.pdf/.svg)
Panel
Properties ‣ Mesh ‣ Paper Model Islands
Menu
Mesh ‣ Unfold
This add-on generates a flat net of a given mesh. It creates either PDF or SVG files suitable for direct printing and paper modeling. The main goal is a maximal possible automation of the whole process. Common tasks like baking the model’s texture into the output document are also supported.
The material! Corrugations!
https://fancymasks.com › what-is-the-best-material-for-cosplay-armor
What is the best material for cosplay armor? - FancyMasks.com
EVA foam is a great entry level material. It is relatively easy to cut and shape. The thickness ranges from 2mm to 20mm, and we recommend 6mm for most beginners. The material is very budget friendly at $0.66 per square foot. EVA foam can be cut with standard household scissors or a utility knife. It can easily be molded to shape with a heating gun.
He ain't no Adam Savage.
What the headline giveth, the last paragraph taketh away. -- Scott Ott
Old 10-09-2023, 04:33 AM   #3 (permalink)
90 day: 38.47 mpg (US)
The name is epic. The first uncivilized man, as the name suggests.
