Old 01-14-2009, 05:50 AM   #11 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
I don't have the gph display, only the mpg and mph so I can easily calculate it. What I remarked is that the mpg display decreases more or less quickly depending on the temperatures, but also the consumption when I change to neutral. If I was accelerating quickly then it takes a lot of time to decrease to the stable idle consumption.
Now when I put in neutral while I was in engine break (DFCO) then the consumption increases to the stable idle consumption. I'm wondering if the strategy can save gas, but I doubt about it as you have to accelerate to a greater speed and loose noticeable speed during the 2 seconds of engine break needed to reach DFCO.
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 01-16-2009, 04:08 AM   #12 (permalink)
AcN
Tibi - '97 Hyundai Tiburon RD1 + LPG
Crazy analysis Denis, thanks a lot
Should get a SG2 someday for my hyundai, or maybe i should just locate the OBDII port before.
Weird the 97 and 01 Renault don't work with it... by the way, what was them problem with that ?
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you."
Old 01-17-2009, 07:12 AM   #13 (permalink)
X-Frenchy: very
groar's Avatar
Diesel
Wanted to know such data since a long time as my iMPG (instantaneous) display in scenic doesn't show any value under 35km/h (22mph) and I'm often blocked in (very) slow traffic.
From ScanTool.net LLC - Powered By Kayako eSupport I found this : OBD Clearinghouse
The looong story : http://ecomodder.com/forum/showthrea...ault-4527.html
My cars are European so EOBD (European name for OBD2) is mandatory for gasoline since 2001 and for diesel since 2004. Both my cars are diesel.
Denis.
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 07:18 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
Altered Idle Speed After Performing EOC Tango Charlie Hypermiling / EcoDriver's Ed 20 11-19-2008 12:41 PM
US Petroleum Consumption vs. Price Per Barrel Matt Herring Off-Topic Tech 10 10-15-2008 09:24 AM
