Old 11-25-2020, 10:49 AM   #1 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Flat tire repair vs weigth savings techiques
We all know extra weigth is not good for MPG. In most cars there are two ways to solve flat tire problem:
Option #1
- Have a spare wheel
- Jack etc needed tools
cons
- adds a lot of weigth 10-30 kg depending on vechicle size
- takes space about 100 liters
- Takes skills and power to replace the tire and open bolts
- Some cases have limited speeds to drive speeds with sparetire
- Takes time for beginner to change the tire -15-60 minutes and you can easily break or car in the process if you dont know what you are doing
Pros
+ Usually can continue driving normally after spare tire is installed.
option #2
- Have a tire seal can which seals and fixes small holes
- Pressure compressor
Cons
- Tire fix foams limited ability to fix tires in cold and if you have a hole to side of tire etc.
- Takes also bit of space
- Seal foams have use before dates, and oem foams are expensive
- Usually messy job
- Tire might leak empty during nigth
- Fix takes time
Pros
+can continue journey if tire holds pressure
+ is pretty lightweigth solution
Option #3
- No tools, sparetire or nothing to fix blownout tires
Cons
- Takes a long time for the road assistance to arrive and tow the car or fix the tire at site
- Is very expensive
Pros
+ Car comes fixed professionally
+ Car is safe to drive after fix
+ LIghtest solution to save weigth and space
Any other options you know?
Some bicycle tires have some expensive glues to put inside tires which in theory fill the hole immediately.
What I know from my own experience is that usually when you are driving you are in a hurry. So when tire is blown your timeplan starts to go bad with all the normal methods.
I would appreciate if you could post here some pictures of your flatout tires and how you fixed the situation, what it cost and how long it took?
Here is my latest mishap. few years old winter tires and screw throug the side which is tricky to fix so it lasts. On that morning had to use other car for the journey. Tried to fix it with can seal no luck with that. Bougth new used set of tires to fix the problem.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 11-25-2020, 11:01 AM   #2 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
Tire shops in the US would not attempt to repair the above damage. I carry a spare tire in all personal use vehicles. All vehicles at work do not carry spare tires larger than a pickup. We have 24 hour emergency tire repair services available.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 11-25-2020, 11:43 AM   #3 (permalink)
90 day: 29.78 mpg (US)
Weight hardly affects fuel economy unless the commute is heavily stop and go traffic, and even then 40 lbs isn't going to be all that significant.
Tire plug kit, pliers, and a mini air compressor is the best option. You can make a repair in as little as 5 minutes without taking the wheel off the car. It would permanently fix about 90% of leaks. Plug kits can be purchased for $2, and inflators for maybe $15.
A tire shop wouldn't repair that screw because it's in the sidewall. Again, I'd just throw a plug in it and see how it holds up. Worst case, a leak develops and I have to replace the tire eventually.
With those type of pictures where the screw is mostly sealing the leak, I get my ream tool and tire plug ready, pull the screw, and quickly ream the puncture, and then quickly plug it. It can usually be done with minimal loss of air so that you don't have to spend an eternity filling the tire.
Old 11-25-2020, 12:07 PM   #4 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Mmm...can 'o inflate & seal, unless I'm going on a road trip. Lots of stop and go in this town...every ounce counts?
Old 11-25-2020, 12:27 PM   #5 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
I use to play the no spare, no sealant game. Once I got a flat though and had to call my Mother to bring the jack and wheel to me so I could replace it I changed my tune. I'm not about to pay for a tow truck or any service fees. I now carry a full size spare with me. Since it's only a 14" rim it's only ~25 lbs. If I was worried about that weight I would remove the passenger seat. The only passenger I ever have in my car is my dog and he doesn't car if he is in the seat or not.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 11-25-2020, 12:36 PM   #6 (permalink)
I'll add that I've used all 4 options multiple times, so I speak from experience. My guess is anyone preferring fix a flat has no experience with plugs. Fix a flat might be capable of sealing some odd things that a plug couldn't, like rusty chrome from a wheel causing a leak from the bead of the tire. I haven't tried it for that purpose, though, so I don't know if it might work.
Old 11-25-2020, 12:41 PM   #7 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
Couldn't agree more. I haven't driven on one to comment on longevity, but plugs are very easy to do and you can get the kit for like $8. The only thing keeping me from relying on plugs, for now atleast, is airing the tire up after when I am out and about. I haven't been impressed with the compact air compressors I've seen so far.
1995 Mercury Tracer
Old 11-25-2020, 01:46 PM   #8 (permalink)
SkauneJohan's Avatar
The cruiser - '93 Mercedes 200D
90 day: 38.11 mpg (US)
The rocket - '94 Mercedes E220
90 day: 32.29 mpg (US)
miss Habanero - '95 Audi A6 2.5 TDi Avant
90 day: 43.52 mpg (US)
Annie - '89 mazda 626
90 day: 29.51 mpg (US)
Full size spare always, and add it in with your tire rotation
have had a full tire blowout three times(over 20 years of driving Both personal and in jobs) that is something a plug cannot fix and definatly no spraycan either
1993 mercedes w124 200D automatic 75hp
1989 mazda 626 2.2 automatic 116hp
Old 11-25-2020, 02:00 PM   #9 (permalink)
I've needed a full spare twice in 20 years. I've plugged, gooed, or patched probably 2 dozen leaks in my vehicles, and another dozen for others.
Vekke (11-26-2020)
Old 11-25-2020, 06:13 PM   #10 (permalink)
I'm carring a spare. People around here just don't care and drop nails and metal on the roads from their uncovered trailer and pickup loads of roofing tear off, junk pickup, ect.
Last flat tire I had was a a hole almost big enough to stick my finger in. No plug will seal that.
