Go Back   EcoModder Forum > AltModding > Saving@Home
Old 12-25-2010, 10:33 PM   #1 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 29.13 mpg (US)
Lightbulb watts vs Heat emitted
So I know this is a odd question but I cannot find anything on it online, I have 11 hermit crabs in a tank and the temps have to stay pretty high for them to be happy.
I have been using a small light bulb that is 40w 120v to keep it warm in the tank, well with the cold weather its been getting to not be hot enough and I already have a heating pad on the tank too
So I was wondering if a 60 watt bulb or a 100 watt bulb would increase the temperature in there or is it dependent on the volts?
Old 12-26-2010, 12:11 AM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Most forms of energy can easily be measured in watts and around 95% of the energy going in to your light bulb is being turned in to heat, so a 40 watt bulb is going to put out around 38 watts worth of heat, a 60 watt bulb is going to put out about 57 watts worth of heat and a 100 watt bulb is going to put out around 95 watts worth of heat.
Thing is, where is that heat going? doing something as simple as a chunk of foam between you tank and the outside wall can help alot, same with putting a chunk of space blanket under the tank or an insulated lid if you can still keep it vented so you don't kill them.
Old 12-26-2010, 01:39 AM   #3 (permalink)
A small wattage bulb will heat a large area if it's insulated good. When I was living in NC I had my well house very well insulated and usually didn't need any heat to keep the pipes from freezing, but when I did need heat such as when the temperature was 0 or single digits for a long term all I used for heat was a 75 watt flood light bulb to heat approximately 40 cubic feet and it would get quite toasty in there.
Old 12-26-2010, 04:53 AM   #4 (permalink)
Incandescent bulbs are only about 2.3 - 2.7% efficient, I think? So a higher wattage bulb will definitely put out more heat. The higher wattage bulbs are slightly less inefficient...
Old 12-26-2010, 10:38 AM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
"Efficient" depends on what you are measuring: 5% efficient when used for lighting, but 95% efficient when used for heating
Good for a laugh: Heat Balls.
Random: Look for heatbulbs, which emit radiation at an even higher heat-to-light ratio (making them more "efficient" for heating).
Old 12-26-2010, 10:42 AM   #6 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Power in * (1- Luminous Efficiency) = heat emitted. For the purposes of your crabs, power in roughly equals heat emitted, no matter which lighting technology you're using.
Also check out Heatball :: Uses
Edit: Hah, Piwoslaw beat me to it!
Old 12-26-2010, 04:19 PM   #7 (permalink)
The 40W that the OP asks about is 98% efficient as a heater...
Incandescent light bulb - Wikipedia, the free encyclopedia
Old 12-26-2010, 04:37 PM   #8 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
I'd actually like to replace the light bulbs in my bathrooms with infared bulbs in the winter and then not heat the bathroom with the central heating. Infared bulbs will warm you nearly instantly, basically as soon as the light hits you.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 12-26-2010, 04:42 PM   #9 (permalink)
Ryland's Avatar
Either way, your light bulb is working mostly as a heater and to answer your question directly, a 100 watt light bulb will put out roughly 2.5 times as much heat as the 40 watt bulb.
If you go with a hotter bulb you might think about getting a thermostat as well as insulating, that way you don't cook the crabs.
Old 12-27-2010, 03:12 AM   #10 (permalink)
aero guerrilla
Piwoslaw's Avatar
Then what's the point of getting hotter bulbs???
