Old 08-21-2015, 01:53 PM   #1 (permalink)
Wait... what? Air viscosity increases with increasing temperature?
How do we reconcile the following two viewpoints?
Air viscosity increases with increasing temperature:
https://en.wikipedia.org/wiki/Viscos...osity_of_a_gas
Drag is linearly dependent on density so if you heat the air by 1%, density decreases by 1% and drag also drops by 1%.
https://www.physicsforums.com/thread...e-drag.804563/
So which is it? Does hotter air increase air viscosity (and thus drag), or does hotter air decrease air density (and thus drag)?
Old 08-21-2015, 03:23 PM   #2 (permalink)
You should have read further in that topic on physicsforums.
Both statements are true, it's just that the density effect is much larger than the viscosity effect.
Old 08-22-2015, 10:27 AM   #3 (permalink)
Yup, I see that now. Is there a temperature above which this happens, or does it happen all the time? I saw an equation on the Wikipedia web page, but it wasn't clear to me.
Old 08-22-2015, 01:16 PM   #4 (permalink)
wait
You might want to avoid wikipedia and search out a density altitude calculator online to put you in touch with reality.
We're not interested in 'viscosity',although 'density' is an issue if you want to drive yourself mad.
