Coolant Additive
I put some Wetter Wet coolant additive with my Zerex 50/50. I guess I was a sucker for slick marketing and from what I can tell has not lower my coolant temps but rather increased them.
Maybe its removing more heat from the engine block - but I doubt it -
Is there any actually science to the additive or is it a mystery additive ? |
Is your existing cooling system having problems dealing with the heat? I find that hard to believe unless you have a problem with it. Why add the additive in the first place?
I thought might have some basis or veracity just not finding My normal temps about 181-184 f temp range but now has gone up to 186-190 |
Well, the coolant temperature is controlled by your thermostat, not what liquid you have in the engine itself. The water wetter might help eliminate hot spots in the head or something, but in a non-modified engine I don't see that being a problem as the OEM has taken care of those sorts of things through design.
Interesting..... I swear by it. I use a scan gauge 2 to monitor my water temp and its taken at the throttle body as the coolant circulates through it for what ever reason before the t stat. I notice with no water wetter My coolant hovers around 184 and climbs to 199 til the high speed fan comes on as the outside temp reaches room temp and my grill is blocked.
With some water wetter in the mix I notice the temp hovers around 179-181 at speed on the highway and high as 191 when accelerating. |
Sure you got all the air out of the system?
Good point. One reason you should measure the coolant going into the vehicle. I find when you add the water wetter it makes the coolant go in better and avoid the air traps. I always fill up the over flow bottle so if I miss some it can suck it out as needed and check it a day later.
