Old 09-18-2013, 04:27 PM   #21 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by andyn666 View Post
One thing I did notice was the heater started cycling on and off while i drove it so it would seem while i hypermile my car it doesn't put enough heat into the system to keep the coolant above 85c!
Have you already got a grille block on the car ?
Having less cold air going into the engine compartment makes it warmer here.
Trapping in the engine heat using an underbody shield would also help.
Insulating the bonnet is also an option.
Some do that with an engine blanket.
Others use cardboard ...
Old 09-18-2013, 04:54 PM   #22 (permalink)
Outlander - '21 Mitsubishi Outlander PHEV Design
90 day: 412.06 mpg (US)
I don't have my grill block on at the moment, but it will be going on asap now. As for insulating the bonnet and an under body shield, ford as been kind enough to take care of that for me
Andy
Old 09-20-2013, 05:50 PM   #23 (permalink)
Insulation is worth to try. No wonder many heavy-duty Diesels are fitted with composite valve covers and oil sumps, to keep the heat trapped and suppressing some of the noise.
Originally Posted by wickydude View Post
I think it's better than running the engine idling while the owners has another coffee waiting for his car to warm up and demist.
Gotta agree to that.
Old 09-21-2013, 03:10 PM   #24 (permalink)
Well I've re-installed my grill block and not its only taking 3 minutes to warm the engine to temp and the engine is keeping its temp without have the heater kick back in
Andy
