Old 03-14-2014, 11:23 PM   #1 (permalink)
Heilopower
Platinum Ghost - '14 Ford Fusion SE
90 day: 33.44 mpg (US)
Difference between 75-90 and 90-140
Has anyone had experience with what advantage one might gain in changing from a synthetic 90-140W oil in a differential to the thinner 75-90W synthetic product?
Was wondering if the change would be worth the expense and time involved?
Old 03-15-2014, 02:10 AM   #2 (permalink)
Expense could be massive if you burn up the gears from heat from too thin of a fluid.
Old 03-15-2014, 11:46 AM   #3 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
I drive my Jeep very infrequently, so my fuel economy data isn't that accurate. However, with 85w-140 it wouldn't creep in gear when cold. It also felt like the brakes were dragging unless I drove it until the fluid got warmed up.
The 80w-90 is a much better choice (for me) year round. It's also what is recommended in the owners manual. I was running it only because I had a bad front pinion bearing that was leaking. So I decided it would be a good idea to put it in both front and rear differentials.
I changed back to 80w-90 last summer.
What about a 75w-140? The 85w-140 was a "dino" oil.
Old 03-15-2014, 12:08 PM   #4 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Fords recommendation for
99 Ford F-150
Rear Axle Lubricant
Motorcraft Synthetic SAE 75W140
Front axle (4X4)
Motorcraft SAE 75W90
Old 03-17-2014, 12:19 AM   #5 (permalink)
tpi
I had a '97 F150 which needed a differential rebuild once in the 70,000 miles I had it (using stock lube). I then bought a '99 F250 w/ 10.5 ring gear differential. I was commuting with it-all mild flat freeway- and swapped out the fluid to 75W90 thinking my situation was easy on it. I did tow about 5K miles in 110,000 miles. Well....that differential was screaming loud at 110,000 miles and needed complete overhaul. I had changed the fluid to Amsoil synthetic at about 20K so the lighter than spec fluid was in 90K.
I've owned a lot of vehicles and very rarely had differential problems. I will never be tempted to use lighter than spec gear lube in any Ford products again.
