I drive my Jeep very infrequently, so my fuel economy data isn't that accurate. However, with 85w-140 it wouldn't creep in gear when cold. It also felt like the brakes were dragging unless I drove it until the fluid got warmed up.
The 80w-90 is a much better choice (for me) year round. It's also what is recommended in the owners manual. I was running it only because I had a bad front pinion bearing that was leaking. So I decided it would be a good idea to put it in both front and rear differentials.
I changed back to 80w-90 last summer.
What about a 75w-140? The 85w-140 was a "dino" oil.
