Old 12-02-2008, 12:53 PM   #1 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
Corolla ECM Data
I was looking for just a pinout of my car's ECU (ECM as Toyota calls it), and stumbled across the PDF linked to in the 9thgencorolla forums.
Not only does it give me the pinout to find where I can tap in for my Guino, but also waveforms and voltages of fuel injector and vehicle speed signals.
Can anyone help me decipher this into Guino settings so I can maybe skip weeks of "dialing in"? Please? Pretty please with fuel savings on top?
Old 12-02-2008, 01:09 PM   #2 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Subscribed. I have 4 9th generation corollas in the family and mine is an 8.5, which has the same ECM if I'm not mistaken. Don't want to lose the thread.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 12-03-2008, 10:13 AM   #3 (permalink)
Ex-lurker
If my maths is correct, which I doubt (and can't compare live since it's not installed yet), the VSS goes something like:
20 msec/pulse @ 12 mph
12 mph = 5 minutes/mile
20 msec = 0.0003333 minutes
(5 minutes/mile) / (0.0003333 minutes/pulse) = 15000 pulses/mile?
Does that sound logical? Seems high compared to the values in the Guino wiki...
Trying to convert the fuel injector graph to usable data seems a bit more difficult. First, the graph states that the given conditions are "at idle." That could be anywhere from 800 RPM to 1,200 RPM. There's also no flowrate information for mgal/pulse that could be used to calculate how many pulses/gallon (which makes more sense to me than microseconds per gallon... how does that work anyway?)
Can anyone with better math skills than me chime in? Anyone have the teacher's manual
Old 12-03-2008, 02:54 PM   #4 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
It's not 20 msec/pulse, it's 20 msec/DIV....I think they mean per division on the graph. Going by that, the pulses appear to be approximately 25 msec long. Also, that time is probably time per pulse HIGH....not including time LOW. So, HIGH + LOW according to the graph seems to be.....more like 60 msec/cycle.
300 secs/mile @ 12 MPH......300,000 msec.......(300,000 msec/mi) / (60 msec/pulse cycle) = ~5000 pulses/mile...
Is that more in line?
Old 12-03-2008, 03:17 PM   #5 (permalink)
Ex-lurker
Ah, see, that seems more likely. So my math was correct, my comprehension of graph data was wrong
I'm going to have to go through the Guino workspace thread... I still can't wrap my head around how microseconds per gallon works here...
*edit* - ok I get it, injectors are rated by lbs/hour which can then be converted to microseconds per gallon.
Old 12-03-2008, 04:03 PM   #6 (permalink)
Do you have the Excel spreadsheet that does the conversion for you?
Old 12-03-2008, 05:59 PM   #7 (permalink)
Ex-lurker
Which conversion? Also: there's a spreadsheet?
Old 12-03-2008, 07:56 PM   #8 (permalink)
There's an Excel sheet to convert lbs/hr to usec/gal for you. It's linked to on the wiki page for the MPGuino.
Old 12-04-2008, 04:25 PM   #9 (permalink)
Ex-lurker
OK, using the chart and the estimation from links in the wiki (I may call a Dealer parts dept this weekend to compare) we've got
VSS/mile @ ~ 5000
usec/gal @ ~ 266228338
I'm shooting to get tapped and mounted this weekend, so we'll see. (wow that sounds dirty...)
*edit* - following another link in the wiki, I find 4000 VSS/mile. Well, it'll be around one or the other so I'll know if it's 20% off.
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 09:24 PM
Review: 2009 Toyota Corolla LE (37.9 MPG) RH77 General Efficiency Discussion 22 05-09-2008 04:55 PM
Emissions Standards - "Good For Fuel Efficiency," Consumption Data Says trebuchet03 General Efficiency Discussion 11 04-18-2008 01:15 AM
Win an EM Sticker: guess Dad's mileage (Toyota Corolla automatic). Ends Jan 13. MetroMPG Hypermiling / EcoDriver's Ed 51 02-07-2008 09:02 AM
