Old 06-16-2021, 02:02 AM   #21 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Originally Posted by Tahoe_Hybrid View Post
he can make it STRONGER by adding a coat of bed liner to it....
the engineering problem have been solved
Sometimes, we need stiffness more than toughness. I'd much rather see a full set of numbers on this stuff.
Old 06-16-2021, 04:20 AM   #22 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
90 day: 19.27 mpg (US)
line-x bed liner
Old 06-16-2021, 11:39 AM   #23 (permalink)
That's not the numbers he asked for.
No comment on the Coroplast piece in the video I posted that was curved across the corrugations?
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
Old 06-16-2021, 02:25 PM   #24 (permalink)
He did that by heating the inside with a heat gun where he wanted the bend.
Old 06-16-2021, 03:40 PM   #25 (permalink)
There ya go. Heat gun > bed liner. And cheaper, too.
Old 06-17-2021, 09:34 AM   #26 (permalink)
Anybody actually analyze the failures for their cause? Like web failure or skin buckling, or skin seperation??? Bedliner will stiffen the skin, but if the failure is the web, or skin between the webs, it wouldn't help. I myself shove music wire into the holes every so often to make it linearly stronger but that does nothing to preventing collapse parallel to the webs.
freebeard (06-17-2021)
Old 11-20-2021, 11:56 PM   #27 (permalink)
Casual Modder
White Egg - '92 Nissan NX2000 SE
Last 3: 29.69 mpg (US)
Originally Posted by TimRogers View Post
Even later to the party...
What about these panels?
https://www.homedepot.com/p/FiberCor...C320/206084818
Just to follow up, I did end up using the Corrugated FRP Wall Panel to make my front undertray. It is quite strong and I'm happy with the result.
It's pretty light and strong. This is a 4' long level and a full 5qt oil jug.
The Following 3 Users Say Thank You to TimRogers For This Useful Post:
aerohead (11-22-2021), COcyclist (02-09-2022), freebeard (11-21-2021)
