Old 07-20-2008, 11:37 AM   #11 (permalink)
Nerdcycle - '81 Honda CM400E
Motorcycle
90 day: 61.16 mpg (US)
Trouble - '06 Kawasaki Ninja
90 day: 74.69 mpg (US)
Edna - '13 Nissan LEAF SV
Last 3: 133.3 mpg (US)
Tank - '20 Ford Expedition Limited
Last 3: 17.4 mpg (US)
Originally Posted by whokilledthejams View Post
See, that's what I originally thought, then I started second-guessing myself. It's easy enough to change the logs again, though.
The worst part is, I actually had this straight at one point, because I used to have a truck with somewhat oversized tires, so I actually sat and figured it out way back then (2001 or so).
Edit:
Correct corrections added to fuel log and my spreadsheet.
This boosts my actual FE up quite a bit!
Sorry about that. I wasn't looking at your numbers close enough. Oops.
Old 07-21-2008, 11:30 AM   #12 (permalink)
Daily Driver - '01 Ford Explorer Sport
90 day: 18.12 mpg (US)
Send a message via Yahoo to Tony Raine
Edit:
i just made excel do the work for me. i enter miles (as shown on trip OD), total cost, gallons and date. excel calculates corrected miles, mpg (from corrected miles), cost per mile, and cost per gallon (just so i don't have to enter it manually). then i use that info for my EM fuel log.
oh yeah, i also have it calculate avg mpg, total miles traveled, total gallons used, and total cost.
if anyone needs any excel help, i'd be glad to post up my excel log and my formulas
My Intro
Old 07-22-2008, 12:52 PM   #13 (permalink)
Sandstone Princess - '99 Chevy Sububan LT
90 day: 21.04 mpg (US)
Joe - '02 Nissan sentra XE
90 day: 43.9 mpg (US)
Regal - '03 buick Regal LS
90 day: 33.85 mpg (US)
run along a measured mile and reset your trip odometer at the begging and read it at the end of a mile. That will be how far off you are. 1.2 is running faster...smaller tires .95 running slower...bigger tires. your will get almost an exact measure of the percent off. I do whatever I can to get mine near 1.0, the computer bases so many tuning parameters on speed.
Old 07-22-2008, 01:26 PM   #14 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
What does it take to get a car's speedo recalibrated? I have smaller tires than stock, and I think my stock tires weren't even well calibrated. I'm actually about 5% off, i think.
Old 07-22-2008, 01:57 PM   #15 (permalink)
EcoModding EcoModder
wikityler's Avatar
Gerald - '91 Pontiac Firefly 3dr
90 day: 40.08 mpg (US)
AFAIK on old cars the speedometer pinion would get replaced. On newer cars I would guess that the dealership can change a setting in the ECM.
Old 07-22-2008, 07:16 PM   #16 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Some modern cars and trucks (particularly trucks) that have aftermarket ECU-tuning devices available can recalibrate for tire size changes. Of course, the catch is that this does not actually apply to most people, especially not here. Odds are, you pretty much have to live with an inaccurate speedo/odo. Consult your relevant 'tuning enthusiast' communities where applicable.
Interestingly, on the xB, my non-stock tires make the speedo more accurate, while making the odo read low. The stock size tires work for the odo, but make the speedo about 2% low. It's really bizarre that Toyota did that, on top of the fact the Japanese version of the car uses a yet another tire size (185/60/15, I think).
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Tire Size Improvements Blue07CivicEX EcoModding Central 11 07-25-2008 02:44 PM
Metro valves: common size? an0nymous Off-Topic Tech 5 07-10-2008 08:45 PM
Gas tank size on '93 Civic DX hatch ? Cd EcoModding Central 0 06-06-2008 10:44 AM
Fuel tank size on 2000 Sunfire? bennelson EcoModding Central 10 02-10-2008 09:34 PM
