Costco tires - which is most efficient?
It's way past time to get new tires for my 1991 Camry Station Wagon (yeah, it's a babe magnet).
I'm a fan of costco for their replacement policy and good (if rarely "the best") prices. This leaves me with basically two options to buy during their $60 off 4 tires promotion: (1) BFGoodrich Premier Touring or (2) BFGoodrich Traction T/A These seem very similar, but does anyone know if one will stand up to higher tire pressures or provide lower rolling resistance? I'm in California (Bay Area) for what it's worth (not terrible rain, no snow, mostly dry). |
I take it you have 13 inch rims like I do?
That made me go to BJs wholesale club to get Michelins (44 psi max), when I normally get most stuff at sams club. I decided (after much internal debate) that the tire I got mattered more than where I got it. I realize this is not what you want to hear, sorry 'bout that. :D |
Some Insight owners claim the Traction T/As are a sticky tire when compared to the Bridgestone RE92s. Never owned either one of those BFGs personally, so take it as you will
Sticky as in higher rolling resistance. more grip
Costco Tires
I get all my tires from Costco. I go with Michelins. They seem to generally be a harder tire thus they have a much better tread wear rating than some others. There was another post on here concerning LRR tires and several Michelin tires came up on the list.
You may want to look at more than Rolling Resistance when choosing tires. Better Tread wear will lengthen the life of the tire which will also save you money. Obviously it is better for the environment too. |
I can understand the convenience and price of Costco (I'm a member), but their selection isn't the best. Also note that they will only install the OE tire size on the car.
Have you considered using Tire Rack? They're my #1 choice, with a great selection and very good prices (even when shipping is factored in). The only time I don't buy from them is when they don't sell the tires I'm looking for (i.e. the Falken Azenis RT-615s I use for autocrossing). |
If you do a spreadsheet with the payback time of a gas-saving prius, you might be surprised how long it takes to justify the intial cost in terms of gas saved. I wish I had paid more attention to max tire pressure for a previous set of tires for another of my wagons: pirelli with a max of only 36 psi. :( That was before I found this site, so I have *some* excuse. |
I know it may be around still, but I also suspect that some minor transmission issues today may be major transmission problems in the next 50K miles, so longevity is good, but not the priority. Quote:
Any one with specific knowledge about the BFG tires I mentioned in terms of which: (1) will give me lower rolling resistance? (2) has a higher max PSI? (3) has less material (better for environment in shipping/eventual waste) and lower weight (less rotational mass)? (4) has other good hypermiling attributes? Thanks a million! |
jbrams -
I would read the PDF that MetroMPG pointed out : LRR (low rolling resistance) tires - Green Seal report & list http://ecomodder.com/forum/showthrea...eport-520.html Based on this report, I have seen the Michelin Energy MXV4 Plus tires at Costco. They were expensive, though, $100+ per tire. I used the Green Seal report when I was looking for my tires : My Continental Contact-Pro Tires http://ecomodder.com/forum/showthrea...ires-2642.html I didn't get the ones in the report because the Continental ContiTouring Contact CH95 didn't come in my tire size. CarloSW2 |
