EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Covers for my wheels . (https://ecomodder.com/forum/showthread.php/covers-my-wheels-31717.html)
herberpower 04-11-2015 01:07 PM
Here was watching what was the best measure of tires and rims for my car.
http://ecomodder.com/forum/showthrea...uel-31567.html
The bottom line is that I prefer the extent origuinal 175 / 65R14 .
I bought a steel tire and tires second hand.
I bought a nissan covered second hand.
All this very cheap.
I also bought a waiter trays 400 millimeters . They are stainless steel. I did not find pizza molds of this size. But it closely resembles.
Wheels and tires:
http://i58.tinypic.com/f4rbig.jpg
http://i58.tinypic.com/vnczzp.jpg
Nissan covers :
http://i59.tinypic.com/m7zx4l.jpg
http://i57.tinypic.com/291ysgm.jpg
http://i57.tinypic.com/wgtchd.jpg
http://i57.tinypic.com/kdr0if.jpg
http://i61.tinypic.com/34pgl8y.jpg
http://i57.tinypic.com/1zfqwzq.jpg
http://i58.tinypic.com/fwi15i.jpg
http://i59.tinypic.com/34o3ewi.jpg
you can see that did not fit properly , missing about 8 millimeters to enter completely.
Waiter Trays :
http://i59.tinypic.com/2ic36g4.jpg
without cover nissan
http://i59.tinypic.com/1z20xmb.jpg
http://i62.tinypic.com/33lebew.jpg
with cover nissan
http://i62.tinypic.com/4t55sh.jpg
http://i58.tinypic.com/mtnonl.jpg
the separaccion between the rim and cover nissan . Does worse aerodynamics ?
I had thought that would fit well covered nissan .
Before finding the trays. Had pendado plug holes nissan cover with adhesive tape .
I have thought of. paste or attach with screws. Nissan cover and tray.
Cd 04-11-2015 01:13 PM
You might be interested in these :Spun Aluminum Disc 14 Inch Wheel Cover - Speedway Motors, America's Oldest Speed Shop
Good luck.
BTW, It looks as if you would benefit greatly by creating some gap fillers around the wheels.
herberpower 04-12-2015 09:52 AM
Good luck.
did not know this store. seems like a good solution. bad are the costs of import
my English is bad.
"Gap fillers" are the square holes ?. Is it an advantage?
I can not seem to adjust the covers nissan. more to fit inside.
MobilOne 04-12-2015 01:21 PM
Your English is fine. No need to apologize here. Those trays look great. The "gap filler" that CD mentioned could be anything that fills the space between the Nissan covers and your wheels. Those trays look really nice.
Cd 04-12-2015 02:15 PM
Just as MoblilOne said, your English is fine.
These are gap fillers :Front wheel arch gap fillers - EcoModder
deejaaa 04-12-2015 04:26 PM
I don't like the space between the cover and wheel. will another fit better to remove the 8 millimeters?
I like the trays also.
might see about cutting the covers centers out, leaving the circular mounting parts. attach the tray with screws to the circle. might have to bend the tray edge to make it flush. there is a thread on here somewhere that did that already.
herberpower 04-12-2015 06:45 PM
Today at work I have stolen two cover nissan.
look silly.
I've seen some cover I liked in other cars. I have not stolen any cover. because I do not like to steal me.
okay I get it. after starting a mod. recommend me another mod.
I have a problem here is not called coloplast. I find thin plastic sheets.
methacrylate plates encounter. but they are very expensive.
gap fille before. I would like to cover the bottom of the car first. to lay it flat. the central part is almost flat. the front and rear has many places where air gets.
Another possibility is to use cardboard boxes. but it is temporary. I will open another thread when tested.
herberpower 04-12-2015 07:04 PM
I too worry to eight millimeters of space.
Now I no longer worry so much. I have stolen two decks nissan.
nissan covered with trays wanted to join. to be easily removable. to look at the pressure of the tires without requiring tools.
I've seen as pizza pan molds mounted with screws. I think I'll do the same with my trays.
Xist 04-13-2015 03:16 AM
Herber, if you ever feel the need, if you just write in Spanish, I will translate for you.
Good luck! :)
herberpower 04-16-2015 07:39 PM
I thought at first attach the cover food to origuinal cover.
with screws like this :
http://ecomodder.com/forum/showthrea...tml#post264302
or pasting like this :
http://ecomodder.com/forum/showthrea....html#post5714
I stole the covers nissan . I covers food fastened with screws to the rim. like this :
http://ecomodder.com/forum/showthrea...tml#post190285
I remain so :
http://i59.tinypic.com/30k3mkn.jpg
on deck . mark an X mark and drill two holes three millimeters .
think about making four holes. for more resistance.
http://i57.tinypic.com/2qnbds5.jpg
check the rim to make holes . to cover and rim use a punch and hammer. not to slip the bit. and no fence to one side.
http://i59.tinypic.com/2je9yqc.jpg
after making the holes in the rim. five millimeters . I threaded with a male six millimeters .
http://i58.tinypic.com/j80idz.jpg
use M6x10 screws. galvanized . wide brim.
http://i59.tinypic.com/2psq7lv.jpg
I made the holes six point five (6.5 ) millimeters to the deck. and replace the cover .
to put the screws . 'Four millimeters between the rim and the tire . tighten the screws. will deform a little cover . and I remain good.
It was getting dark . tomorrow I'll have more photos.
AndrzejM 04-17-2015 08:32 AM
Remember to use some kind of thread glue because if screws get loose it can be dangerous for others.
herberpower 04-21-2015 09:57 AM
a screw is lost . and others had loosened. put permanent locking .
http://i58.tinypic.com/307ozgh.jpg
more photos here :
http://i59.tinypic.com/outn3l.jpg
http://i62.tinypic.com/28tdqh1.jpg
I thought to make a hole for the valve with this:
http://i60.tinypic.com/4gs1o6.jpg
Is it good idea?
deejaaa 04-21-2015 10:26 AM
you could get a valve extension and put a smaller hole. otherwise, looks good to me.
how did you mount them different? looks the same to me.
are you using a gauge to see any changes to FE?
BTW, i've read its better to have them protruding like you have instead of mounted flush.
herberpower 04-21-2015 03:34 PM
Seeking the EsTension Valve .
do not use gauge. to see the changes. Can not install.
herberpower 04-29-2015 10:52 AM
the extent of valve. you have to be always mounted ?
to go outside of the cover. they can be beaten with a curb when parking.
deejaaa 04-29-2015 10:53 PM
guess it would depend on the size you get but yes, they will need to extend beyond the cover.
https://www.google.com/search?q=tire...ender&tbm=shop
or just remove the cover every time you need to check pressures and not use them.
