Hi
Hypermilers!
HyperMileQC and I are starting an aeromodding project on a Toyota Echo 2005 Manual 5 Speed 1.5 L : The Echo-Troll Project!
EPA : 30 City \ 38 HWY \ 33 Combined MPG (US)
My MPG's : 52 to 57 MPG in a 4.3 Miles commute \ 60 to 63 mpg on HWY
Up to Date List of my Current Aeromods :
Whiper Deflector (Tested) +1.5% MPG (US)
Wheel Covers (Pizza Pan) (Tested) +2.15% MPG (US)
Partial Front Grill Block (Spring Mod) + Upper Grill Block
Sealed Gaps Upgraded+
Frontal Belly Pan -
Upgraded+
Center Belly Pan
Rear Belly Pan -
Upgraded+
New Front Wheel Spoilers
New Rear Wheel Spoilers
Side Skirts
Passenger Side Mirror Deletion
Planned Aeromods :
Rear Wheel Skirts (
In Progress)
-Front Nose
-Front Wheel Skirts
-Boat Tail
-Boat-Tailing Behind Tires
Inside of the Car Modifications :
ScanGauge II
-Dino Juice To Syntec Oil Swap
-Warm Air Intake
Block Heater
-Summer Tires : 50 Psi (Front). 45 Psi (Rear). (
Current Tires)
-Winter Tires : 40 Psi
-Power Steering Disable
-DRL Disable
Planned Inside Modifications :
-Next Oil Change (Mobil1 0w-20)
-Syntec Transmission Oil Swap
-Alternator Disable
Kill Engine Switch
-A/C Deletion
-Taller 5th Gear
-LED Lights
-LRR Tires
-Wind Tunnel from Grille Block Hole to Radiator
The Ultimate Goal :
Our goal is to reach the 3.0 L/100Km (78.4 MPG) Score at 50 MPH and maybe 2.5 L/100Km (94.09 MPG) Ultimate goal. For now we haved reached 3.8 L/100Km (61.9 MPG).
The Car :
You can see here the Echo-Troll with one of it's first Aeromod, the partial grill block for summer.
If you have any ideas or suggestions for this project, please, let us know by posting in this thread. Thanks.
