Old 03-19-2015, 10:41 PM   #1 (permalink)
herberpower's Avatar
Dominates Everything - '88 Honda NX650 Dominator
90 day: 50.55 mpg (US)
Mini scooter - '15 Ride E1
90 day: 615.21 mpg (US)
Conor City 350 E-Bike - '03 Conor City 350
90 day: 907.26 mpg (US)
Maxi Scooter - '09 Vectrix VX1 NIckel Nickel
90 day: 233.45 mpg (US)
Vectra B - '01 Opel Vectra B Elegance
90 day: 27.77 mpg (US)
Tires . Which thinks that saves more fuel ?
My car brings tires 175 / 65R14
I searched the lighter rims and found the opel corsa a gsi .
17,2 lbs (7,8 kg) 5j x 14 4x100 et47,5
carries four tires 185 / 60R14 Michelin energy + .
Two of the tires were bad. I've changed some 175 / 65R14 primewell ps880 .
175 / 65R14 is more popular.
I can save by switching the measure 165 / 70R14 ?
Do I best with 175 / 65R14 ?
Car:
Motorcycle:
Scooter:
E-Bike:
Old 03-19-2015, 11:05 PM   #2 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Get Bridgestone potentza Re92's. 165/65R14. Best tire in terms of MPG by far.
The Following User Says Thank You to Baltothewolf For This Useful Post:
The donkey CRX (03-20-2015)
Old 03-19-2015, 11:23 PM   #3 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by herberpower View Post
I can save by switching the measure 165 / 70R14? Do I best with 175 / 65R14 ?
Try 165/70. Generally, narrower and taller versions of the same tire are considered better for fuel economy on this site. Some will disagree. Michelins are good. Bridgestones are good. I don't know of any completely current tests comparing LRR tires. I have Michelin Defenders on my car and love them, but the "Defender" name is probably not available in Spain.
Old 03-20-2015, 07:57 AM   #4 (permalink)
165 / 65R14
bridgestone re92 not find
I found :
bridgestone b250 F E 70 db
Bridgestone Ecopia EP150 C C 70 db
Michelin energy + C B 68 db
165 / 70R14
I found :
bridgestone b250 FE 70 db (it is difficult to find)
Car:
Motorcycle:
Scooter:
E-Bike:
Old 03-20-2015, 08:10 AM   #5 (permalink)
90 day: 55.9 mpg (US)
I think the 165/65 R14 are too small.
165/70 R14 are very slightly bigger than the original 175/65 R14s.
You may consider using 165/75 R14.
Those are available from Michelin and others and are 1 cm taller than the 175/65 R14s.
(cracking the numbers: )
The second number is the height of the sidewall as a % of tire width.
So 175/65 = 175 mm * 65% = 113.75 mm high.
165/65 = 107.25 mm, that's 6.5 mm lower than stock.
165/70 = 115 mm high, that's 1.25 mm higher.
165/75 = 123.75 mm high, that's a full centimeter more.
If you go for 165/75 R14s remember to add 3.3 % to your odometer readings, as those will display 3.3 % less than stock on those tires.
Likewise, the speed shown is less than stock; as speedos usually show a substantially higher speed than real, it will only become more precise.
Old 03-20-2015, 08:21 AM   #6 (permalink)
LLR tires nothing .
You can explicrme that is.
here's tire saving fuel.
It's the same ?
narrower versions need a higher profile. to have an equivalent diameter .
Is there much difference ?
175 / 65R14 and 165 / 70R14
previously used wheels with tires 175 / 70R14 .
consumption increased slightly.
It was better in the bumps.
was best at speeds of 90km / h ( 56 mp / h ) or higher. lower rpm . Less engine noise.
here in Spain and in Germany. are said to michelin tires are best. and that more lasting . are the more expensive price .
Car:
Motorcycle:
Scooter:
E-Bike:
Old 03-20-2015, 08:54 AM   #7 (permalink)
Those 175/70 tires have a 8.5 mm higher sidewall than the 175/65s.
So they were about 3% bigger than the 65s.
If you did not compensate for their size in the odometer readings, and you seemed to use 2% more fuel on them, in reality they were saving you 1%...
If 175/70 R14s were OK, then get the 165/75 R14; those are just a few mm taller.
Old 03-20-2015, 09:45 AM   #8 (permalink)
175 / 70R14 are 3% more than the 175 / 65R14 . and I can use them.
here allow a limit of + -3% in diameter.
165 / 75R14 is 3.5%. not allowed.
Car:
Motorcycle:
Scooter:
E-Bike:
Old 03-20-2015, 09:45 AM   #9 (permalink)
Cyborg ECU
LLR tires nothing .
Sorry. "LRR" indicates "Low Rolling Resistance." Tires marked LRR in the USA are specifically for fuel economy.
James
Old 03-20-2015, 10:51 AM   #10 (permalink)
James
Here European tire label is used.
Car:
Motorcycle:
Scooter:
E-Bike:
