Old 05-06-2011, 10:03 PM   #1 (permalink)
Buggie - '01 Vw Beetle TDI Gls
check your brakes
just got stranded for a while, fron brakes seized on, just enough that i noticed a big drop in FE. seemed ok once i parked for an hour. On the way home (3 hours) I downshifted and used the e-brake to stop, not wanting to get the front pads to seize on again. I did notice a slightly better FE than normall after not using my brakes for an hour and a half
Anyways, I got the idea that after driving for a while I should check the brake temperature to see if brakes are sticking, a small pressure would not be noticable whike driving but woudl affect Fe. If you can drive a while and pull over without using the brakes, you may get an idea if you may have a slightly sticking brake just by touching the rim, or if you can, the rotor, mine were nice and cool by the time i got home
Old 05-06-2011, 10:08 PM   #2 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Good call.
The iron in sintered metallic brakes swells as it rusts. At the edges of the pads, the rotor doesn't remove the swelled-up iron and they drag. Its spring and humid in some places and rust accelerates.
Also, its a good time to check tire air pressure.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
