CRX HF EcoTurbo?
Well gentlemen.
Is it worth it to turbocharge a 1990 Honda CRX HF for increased economy? I read an article in SuperStreet a loonngg time ago, in which a turbo Honda S2000's fuel economy jumped to 38 mpg. All because it took him less time and throttle to achieve highway speed. I was thinking maybe a Mitsu 13G with an adapter plate to the HF manifold, plumbed straight into the throttlebody with no intercooler. Boost pressure would be low, only 5 psi or so. I would like to retain the factory 240cc injectors. My biggest concern is tuning with OBD-0. |
Doesn't the CRX HF have pretty high compression ratio already and with a turbo you want to have lower compression on your engine so the increased pressure doesn't cause pre-detonation.
The GT15 would probably be a little more efficient for my needs, and spool a little faster... However, that would increase the price by quite a bit. Quote:
The short answer is no. |
A guy on d-series.org boosted his civic for the sole purpose of better FE. He tuned it so that his engine would be in neutral vacuum as much as possible to increase pumping efficiency . He also re-calibrated the fuel maps in his ecu to run in lean burn mode. I forget how many MPG's he was getting but is was up there. I'll try looking him up and post a link if I find it.
I would be surprised if just adding a turbo helped FE in any way.
Using a turbo to bring a car back to "acceptable" performance when something else has been done (e.g., lean-burn, downsizing the motor, etc.) is a well-trodden path to FE. Just ask anyone with a Cruise Eco. It might be fun to run a 1st-gen Insight 3-cylinder with a turbo in a CRX. :D -soD |
Gasoline engines don't see much of a FE boost when turbo charged.
If you be good and drive them easy you can milk a few more MPGs out of your vehicle but the mod wont pay for its self. It would be nice to have more power and MPGs, in that way it could be worth it. I wouldn't try going non-intercooled. |
