Old 06-12-2009, 05:23 PM   #11 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
HF wheels are steel but just over 12 pounds instead of over 15 pounds for stock wheels, VX wheels are around 11 pounds, same with HX wheels (I think), those wheels will all let you go with narrower tires.
change your tranny oil, every two years, I suspect it has been nearly 20 years on that car.
Old 06-12-2009, 10:48 PM   #12 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
Originally Posted by Christ View Post
Why change technique with speed? It doesn't matter what your vehicle speed is... the engine speed will be at idle while you're in neutral (unless you turn the engine off, in which case it doesn't matter if you're in neutral or clutching).
The problem with clutching for extended periods is that the clutch release bearing doesn't have a cooling mechanism. It will heat up, and eventually, it will fail. Best bet, regardless of speed, is just to pop the gear selector into neutral. (I don't even use the clutch pedal to take the selector out of gear... just pull it out while you're letting off the gas pedal, and it will slide right out.)
I do clutch-in coast in short bumper to bumper driving but you make a good point
One that I was considering
Also the belt has been changed a year ago as well as transmission fluid
But all will be inspected once I start my rounds
Past Present Future?
Old 06-12-2009, 11:04 PM   #13 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Things to get you started.
Well, first things first... when you do your tune up, try replacing your oil with something lighter than spec... Mobil 1 makes a good synthetic that lasts long enough to make it cost-effective, at $22 per 5 qt bottle. Use the largest filter you can come up with that fits... an FL-1A might fit, I'm not sure. You'll have to ask around on some Honda forums, or maybe even in here. Use the largest filter you can get, for higher capacity and better oil cooling, and longer change intervals. If you get the 0w30 oil, it performs on the same standard as 5w30 oils.
Change your plugs and wires, just for the sake of doing it, even if they're not bad... you won't need to change them again for god-knows-how-long.
Check that your wheel bearings are moving as freely as possible, and all suspension components are operating as they should.
Being an Si - you have power steering, most likely... this can be removed, if you can't find a manual rack to use (I have one), then you can just loop the lines together. You'll have a slightly different steering ratio using a manual rack.
If your tires need to be replaced, 155 R13 tires on '84 Si wheels are just about the lightest option. If this isn't light enough, you can use load "E" trailer tires... they're steel wheels, 5.30x12" They also have a 4x100 bolt pattern on the 4 lug wheels. (I use Honda wheels on my trailer... ) I don't necessarily recommend the trailer tire thing unless you're staying in the city and not going much over 45... but I've never tried it, so I can't say if it's safe. I can't imagine why not, since they're rated higher than passenger tires are, but meh, someone will have something to say about it.
Please, check to make sure your headlights are properly aligned. After doing so, close up all the holes around the hood and above the bumper. You can fill in about 80% of the bumper grille even in HOT weather using the stock engine, if your cooling system is completely operational.
Check/clean/replace ALL ALL ALL ALL ALL ALL ALL ALL ALL ALL ALL ALL THE GROUNDS on the car... not just the one by the battery, not just the one on the head cover, ALL OF THEM. You can usually get another 1-2 MPG by doing this, as you lessen the electrical load on the engine (alternator) by cleaning up the flow path of electrons. You can also upgrade the primary grounds with high-conductive wire and lugs. (You can get wire from stereo shops, you can make lugs from soft copper tubing.)
If you don't use the sunroof, you can remove the glass and replace it with aluminum or fiberglass, etc... this will save you a good deal of weight, and keep the interior cooler during the summer.
Old 06-12-2009, 11:07 PM   #14 (permalink)
Before you go spending a boat load of money on the engine that's in it, consider getting yourself a D15Z1 or a D16Y8 head and any other D15 block if you know how to build engines or can learn.
If you take the latter option, you'll still need the ECU/wiring setup for the Z1, but it's a cheaper way (sometimes) of getting that engine together.
Old 06-13-2009, 11:12 AM   #15 (permalink)
Grasshopper
thanks for the info, good stuff
ill try to maintain it but if something happens along the way
theres always the ev route
Old 06-13-2009, 02:06 PM   #16 (permalink)
Crx
I can only speak for the 1st-gen CRX.I did a nose overfascia with integral grille-bock,front wheel-well gap-fillers,rocker panel extensions,under-body cleanup,full rear wheel skirts,over-hatch bi-wing spoiler integrated into a 12-inch boattail with full underside,and Moonies.------------ The "kit" added 8.6-mpg at a constant 55-mph,pushing mpg from 52,to 60.6 mpg ave.The cars personal best was 75.8 mpg between Cloudcroft,N.M. and Denton ,TX.Top speed increased from 93-mph to 100 mph ( close to sea-level ).
Old 06-13-2009, 10:24 PM   #17 (permalink)
Grasshopper
cool stuff
got a link to your thread or pictures?
id love to see the nose and boat tail
also
its not really worth $300 when you can go to the store and copy it for $20
but hows the aero on this?
Old 06-15-2009, 04:20 PM   #18 (permalink)
pictures
cool stuff
also
Alohaspirit,I'm gonna try and link some pics from my photo album in the archive.Fuel Economy, Hypermiling, EcoModding News and Forum - Ecomodder.com Fuel Economy Forum 155-1991-after visit-rocky-mountain-institute-itworks-aero.html------------------ http://ecomodder.com/forum/member-ae...ml------------ Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com - aerohead's Album: Other vehicles 1 - Picture
Old 06-15-2009, 08:20 PM   #19 (permalink)
Grasshopper
the first link didnt quite work but the other two did
but that is EXACTLY what I was looking for
awesomeness
Old 06-25-2009, 06:53 PM   #20 (permalink)
3rd photo
Here's another try at the photo link------------------------------------------- Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com - aerohead's Album: Other vehicles 1 - Picture
Which CRX? seanof30306 EcoModding Central 8 02-10-2009 05:52 PM
1991 Honda CRX - New Here... Hi, Everyone! adam62882 Introductions 4 09-28-2008 10:35 PM
New guy with a 1990 crx hf. gasnmyveins EcoModding Central 6 09-06-2008 01:21 AM
Repping the old school Hondas - 85 CRX HF 1GCRXHF Introductions 4 06-16-2008 01:14 PM
non-op '85 CRX, or '91 civic hatchback SirKeats EcoModding Central 1 05-16-2008 04:21 PM
