Old 06-08-2014, 07:21 PM   #1 (permalink)
...beats walking...
Cummins™ does FE for semi's
Found this interesting reading:
https://cumminsengines.com/uploads/d...el_economy.pdf
...especially their summary:
Rock-Solid Rules
Every 2% reduction in aerodynamic drag results in approximately 1% improvement in fuel economy.
Above 55 mph, each 1 mph increase in vehicle speed decreases fuel economy by 0.1 mpg.
Worn tires provide better fuel economy than new tires, up to 7% better fuel economy.
Used lug drive tires can get up to 0.4 mpg better than new lug tires.
Ribbed tires on the drive axles provide 2–4% better fuel economy than lugged tires.
Every 10 psi that a truck’s tires are underinflated reduces fuel economy by 1%.
The break-in period for tires is between 35,000 and 50,000 miles.
Tires make biggest difference in mpg below around 50 mph; aerodynamics is the most important factor over around 50 mph.
The most efficient drivers get about 30% better fuel economy than the least efficient drivers.
Idle time is costly. Every hour of idle time in a long-haul operation can decrease fuel efficiency by 1%.
The Following 4 Users Say Thank You to gone-ot For This Useful Post:
mikeyjd (06-08-2014), radiantthought (06-08-2014), UltArc (06-08-2014), Xist (06-08-2014)
Old 06-08-2014, 08:05 PM   #2 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Good find.
