Old 12-04-2009, 11:21 PM   #31 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
Inb4 all this BS again that happened with Hermie.
Old 12-04-2009, 11:21 PM   #32 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
That does it. I'm gettin' on the hatewagon.
Old 12-04-2009, 11:26 PM   #33 (permalink)
How much are tickets?
Old 12-05-2009, 12:07 AM   #34 (permalink)
Wanderer
Sorrow Six Star's Avatar
Winona - '86 Subaru XT DL
Originally Posted by Sean T. View Post
You forgot:
3. Hatewagons are more aerodynamic usually than hatepickuptrucks, but less aerodynamic than hatehatchback-ecoboxes.
please quit killing my IQ points... I NEED those!
Originally Posted by bgd73 View Post
Legends are legends after all..
Old 12-05-2009, 12:10 AM   #35 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Yet another thread I'm about to jet from. Pce out, guise.
Old 12-05-2009, 12:23 AM   #36 (permalink)
Wanderer
oh Christ.... been dieing to say that.
Old 12-05-2009, 12:58 AM   #37 (permalink)
1. There might be confusion as to the purpose of a boattail.
2. What flavors does haterade come in?
1) Isn't the purpose of a boattail to cause cross section to decline rearward, IE create inward-slanting surfaces? That's what we are talking about here, cutting holes in the bumper fascia, or trimming it like in my examples.
2) It comes in "Front Aero Doesn't Matter Fruit Punch", "You Don't Need Downforce At Hypermiler Speeds Strawberry Surprise", "Just Add Wheel Skirts Juice Blend", and "Engines Don't Need Cooling Kiwi".
Edit: I forgot "That's For Racecars Where Only Downforce Matters Rasberry" which is the haterade being drunk in this thread.
Old 12-05-2009, 01:03 AM   #38 (permalink)
The Aerodynamic Performance of Automotive Underbody Diffusers
The data acquired demonstrate that an underbody diffuser can significantly increase downforce, and can provide some drag reduction if ride height is not too small.
Old 12-05-2009, 02:13 AM   #39 (permalink)
So you're saying that those holes produce negative lift?
I'm relatively sure they don't produce anything, actually, rather negating positive lift that would normally be occurring due to the parachute effect. The notion still stands that the parachute effect wouldn't be a problem if the offending area were covered by body work, hence the obvious advantage of a rear belly pan, or the option to just cut the offending section of the rear bumper, rather than add the ineptly named "speed holes" to it.
If that wasn't your complaint, I'm not sure where the relevance was.
Old 12-05-2009, 01:15 PM   #40 (permalink)
What you are basically saying is that a hatchback isn't more aerodynamic than a wagon. The plain rear belly pan would be like the wagon, and cutting the lower edge or making holes (big enough holes) would be like the hatchback or adding a boattail. Air doesn't care whether it's flowing past the top or the bottom of a car.
Do Rear Spoilers / Wings Help Any? Jammer Aerodynamics 27 12-30-2021 10:56 AM
Rear Alignment: Drivability vs Economy Southcross EcoModding Central 11 04-22-2009 09:40 PM
Rear Parachute NewBModder EcoModding Central 8 09-17-2008 06:42 PM
vortex generators at rear bumper?? crexcrex Aerodynamics 14 08-22-2008 05:11 PM
advice - Jeep under bumper something? hans2vt Aerodynamics 6 07-07-2008 03:16 PM
