Old 06-08-2009, 08:21 AM   #11 (permalink)
blueflame's Avatar
In scooters you can use heavier weights to up the overall ratios, or pulleys with different ramp angles. Wider belts give you greater top speeds.
I'm sure the cars are different but I have no idea
Old 06-08-2009, 06:24 PM   #12 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Yeah, its definitely a different beast. I didn't know that the planetary setup did the entire work of the tranny. I kind of get what you're talking about Bob. Thanks for the explination.
No problem although it took awhile to wrap my head around it.
It is quite an amazing package over all. I took my first drive this weekend in an 04 Prius, and with the wife driving at a steady 65 mph down the highway, we were getting about 55 mpg. Thats pretty hard to beat. No special driving, just a smooth foot on the accelerator.
I'm sure we learned things the Chief designer didn't know. The Prius is really a nice, technical puzzle.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
Old 06-08-2009, 08:09 PM   #13 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.7 mpg (US)
Originally Posted by Christ View Post
What a CVT should be = two mechanical centrifugal clutches, one that opens with speed, one that closes with speed, and an idler pulley.
This is what my PUG had... 3200 RPM, in high gear, was about 28 MPH.
Lose some drag and drop the idler pulley. My Burgman doesn't have one.
Old 06-08-2009, 11:03 PM   #14 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
My first thought would be an ecu tune . . . . .
Not sure what ecu's have been cracked as of now . . . .
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 06-10-2009, 07:56 AM   #15 (permalink)
MPG...what?
Terkle - '97 Toyota Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '10 Toyota Yaris base
90 day: 41.88 mpg (US)
Deva - '13 Chevrolet Spark LS
90 day: 39.82 mpg (US)
Malibu5 - '82 Chevrolet Malibu Classic
90 day: 17.61 mpg (US)
Highlander - '06 Toyota Highlander Limited
Send a message via AIM to malibuguy
our Caliber has a CVT....less throttle = taller gearing, when i floor it it just holds redline as it gradually adds in more ratio to maintain it & add speed
-Greg...the exhaust freak.
-06 Highlander 3.3awd
-10 Yaris sedan
-97 Tercel, 1NZfe swapped
-96 Tercel
-82 Malibu 1UZfe swapped
-19 Fit (wifey ride)
www.pipedreamsfab.com
Old 06-10-2009, 08:24 AM   #16 (permalink)
I guess I'd need to drive a CVT with a scangauge installed to watch rpm vs tps vs load to see how they react.
Old 06-10-2009, 08:51 AM   #17 (permalink)
MPG...what?
its very weird at first, but eventually i got used to it & kinda liked driving it, it pulls mph on the top end really good, out of the hole tho...its a slug, i pulled something like a 2.6 or 2.7 60ft, but ran a 16.99@83mph with a 15mph headwind on a cool day, its like driving a large rubber band
-10 Yaris sedan
-96 Tercel
Old 06-10-2009, 09:21 AM   #18 (permalink)
Mechanical Engineer
The Truck - '02 Dodge Ram 1500 SLT Sport
90 day: 13.32 mpg (US)
The Van 2 - '06 Honda Odyssey EX
90 day: 20.56 mpg (US)
GoKart - '14 Hyundai Elantra GT base 6MT
90 day: 30.36 mpg (US)
Godzilla - '21 Ford F350 XL
90 day: 8.69 mpg (US)
I've seen a PUG, but it's been years. As I recalled it had a garden-variety "snowmobile clutch" mechanical CVT, but you're either misunderstanding this type of trans or describing something entirely different.
Rubber belt CVTs have a centrifugal drive clutch that closes with speed against spring pressure and a driven clutch that is not centrifugal in nature that opens along a ramp against a spring responding to belt tension. Sometimes the post of the drive clutch has an idler bearing to reduce transmitted torque at idle speed. Sometimes the centrifugal clutch is mounted to a go-kart-like starter clutch to disengage it from the engine at idle speed. Neither of these last two are specifically required nor common on low-end machines like PUGs and similar contraptions.
Coming off idle the centrifugal drive closes a little putting pressure on the sides of the V-shaped drive belt, transmitting torque along a small radius of the sheave faces. Because belt tension is low, the belt rides along the largest radius of the driven clutch sheaves yielding a numerically low transmission ratio. This allows the vehicle to begin moving as the engine spins up to "shift RPM" (where the clutch begins to shift ratios) at which point you are typically generating as much horsepower as you can for the conditions (speed/load). Assuming you keep your foot planted to the floor the vehicle speed increase allows the engine to begin to speed up above shift RPM at which point the drive clutch's centrifugal force increases, increasing belt tension, pushing the belt up the drive sheave faces and pulling the belt down the driven sheave face, continuously decreasing the numerical drive ratio. This increases load, pulls engine speed in line with shift RPM, and so continues the cycle. Once maximum drive ratio is achieved (assuming WOT all the way) the engine can speed above shift RPM up to engine governed RPM.
If you settle into part-throttle cruise as some speed between idle and full RPM at full shift-out, the decrease in horsepower (and therefore torque) of the engine decreases the tension in the drive belt allowing the drive clutch to balance the rpm-specific centrifugal forces against the driven-clutch's spring pressure and ramp angle. This shifts into numerically lower ratios, pulling down engine RPM. Engine load as a percentage of available torque will increase as the RPM decreases and CVT shifts out, all while the vehicle is traveling at a steady speed on flat ground. Encountering a hill or increasing throttle changes this equation and the CVT back-shifts to bring up engine RPM and increase reserve torque.
Automotive CVTs are all computer-controlled electro/hydraulic contraptions these days. Computer programming controls how they respond, whereas with snowmobile clutches it's all simple physics and geometry. I've driven a Caliber CVT rental and I adapted to it quickly since in my experience it behaves very much like a mechanical rubber belt CVT. I would definitely recommend driving such a vehicle with a scangauge. I think throttle modulation and driving style, along with frequent neutral coasting, would benefit you greatly. I do recall the Caliber had a bit too much engine braking dialed in (something CVTs rarely do well, so some computer controlled ones over-simulate it).
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 09:31 PM
Increasing gear ratios extragoode EcoModding Central 29 05-23-2011 03:36 PM
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
Custom 5th gear ratios? rkcarguy EcoModding Central 15 09-05-2009 03:41 PM
Diesel Gear Ratios trikkonceptz EcoModding Central 6 01-08-2009 03:41 PM
