Old 05-20-2008, 02:48 AM   #1 (permalink)
The Move - '99 Daihatsu Move Aero Down Custom XX
90 day: 29.89 mpg (US)
Send a message via AIM to Dust
"Hypermiling" counterproductive?
If you take a look at my mileage, you will see that I have a few tanks in the log. The worst one was being nice to the car. No boost, slow starts, watching lights, etc. Yielded 10.4something KMPL. The next tank, before I got tires for the car, was a lot of boost, climbing a mountain, and not really being nice to it. Yielded me 15.4 KMPL. The tires were a little mismatched when I bought the car; 165/55/14 and a 155/65/14, and I filled up early on the last tank to kind of reset after buying new tires and an alignment. I used some Fuel Power Plus for the first time on the third tank, and a stronger dose on the 15.4 tank. That’s a lot of difference. Is it because I didn’t have much throttle on the 10.4 tank, and more throttle makes better mileage? What am I missing?
Old 05-20-2008, 03:43 AM   #2 (permalink)
Piaggio Fly 150 - '10 Piaggio Fly 150
90 day: 64.8 mpg (US)
Engines actually run more efficiently (per kw/hp) at wider throttle angles so you can actually accelerate too slowly for FE and its better to cruise/hill climb in a high gear with open throttle then at high rpm/low throttle. You should probably look at your engines BSFC map to see where to keep the engine.
Check out my Green Cars Blog and the DIY electric car Wiki. Enjoy!
Old 06-01-2008, 08:01 PM   #3 (permalink)
With a turbo in the mix, does pulse and glide include getting into boost too?
Old 06-01-2008, 08:08 PM   #4 (permalink)
Do you have a scangauge? If so, set it to monitor closed/open loop mode. You should be accelerating as hard as you can without bumping it into open loop mode. In open loop you will be running rich air/fuel ratios and loosing the benefit of P&G.
Old 06-01-2008, 08:21 PM   #5 (permalink)
No OBD2. Really wish it did though. Life would be easier. May pick up a wideband though, although the cost benefit would be rather dim.
Old 06-01-2008, 08:36 PM   #6 (permalink)
Check out this dodad. It should allow you to monitor open/closed loop. I made and used one for a while on my 96 Tercel.
http://autospeed.com/cms/A_1716/article.html
