Dealing with underside airflow & the front bumper (transition radius to undertray)
It seems to be warming up, and that means I can actually work outside more (this year's cabin fever has been horrible). So, I'm looking at a bellypan for the Paseo and have been thinking about how I want to make the transition between the front bumper and the pan. In the picture below you can see the car currently has a small air deflector on the bottom (all current stock equipment is gray). I'm thinking the best route to go with a bellypan would be to drop down to that level from the front of the bumper (see the red dots in my pic). Any ideas or comments?
Here are my less than great pictures: http://www.tercelreference.com/downloads/panels_5.jpg http://www.tercelreference.com/downloads/paseo.jpg http://www.tercelreference.com/downloads/front.jpg |
Sounds reasonable - you definitely want a radius between the bumper bottom and the pan, if possible. See the EV-1 for example:
http://a332.g.akamai.net/f/332/936/1...v1.f34.500.jpg There was a pic out there of Brigham Young U's EV1, shot from underneath the car on a lift that better shows the bumper/front pan transition. But I can't find it at the moment. What does Hucho say on forward facing transition radii? 2 inches? |
Thanks for the pic. That is pretty darn close to what I was thinking of doing with my bumper actually. I was thinking of adding a vent for the radiator in the front radiused section of the underbody panel. In any case, I think I'll use the EV-1 as a template.
I'll have to look at Hucho's book. I haven't been reading it much lately and am only on chapter 4. But, I believe he said something like 2-4" when he was describing the VW bus. I remember the section, just not the exact number. |
Daox -
I like the shape you were thinking of. An alternative I have been thinking about is to find an old bumper of my car from a junk yard and "double-deck" it : http://img80.imageshack.us/img80/389...mperhf7.th.jpg I think this would be harder for you than for me because it's easier for me to find a Saturn bumper. I would call this the "Biplane Mod". CarloSW2 |
What about doing something a bit more drastic? Reshaping the front a bit more like such? It would be much more of a bland look, but I would think a bit more aerodynamic.
http://www.tercelreference.com/downloads/front1.jpg |
You'd be lowering the stagnation point, and sending more flow over the car than under (as well as increasing front downforce).
But will that reduce drag? Not sure. But I'd guess "yes", since you're diverting more air away from the dirty underside. |
( When there is a bellypan installed . ) Why is this ? Does it add more / less velocity to the airflow travelling under the car ? |
It helps keep the flow attached. In the book it references A pillars more so than underbody airflow. However, the principle is still there.
Raises an interesting question though: if there's no belly pan for the dam to transition to, is a lower radius strictly necessary?
