Deceleration Alternator
I was thinking tonight about making my alternator kill, into a deceleration alternator. Would give me atleast a couple extra miles of run time that way.
I am using a Potter-Brumfield 70a relay to disconnect the output, and a Bosch 30a relay to kill the field wire. I was thinking of putting in a switch like this. Nitrous Oxide Systems (NOS) 15640NOS - NOS Micro Throttle Switches - summitracing.com on the throttle to be activated at idle position, but also connected to the clutch pedal through a set of relays as well, Basically only allowing it to run alternator when clutch is engaged and throttle is at idle. This way avoiding pretty much all conditions except for neutral idling, and deceleration. I figure if the car is idling it might as well be doing something, and DFCO sounds like a good time to charge the battery to me. Suggestions? If it sounds feasible I could possible get some diagrams started and a How-to. I have it stuck in my brain and need to get it out. :D |
Sounds like a good idea but if your clutch is engaged you won't be in dfco, your car will just be idling like in neutral. DFCO occurs when you coast in gear above a certain rpm range- in my car it kicks out of dfco at about 900 rpm.
Clutch engaged while driving, dis-engaged while coasting, shifting.
http://en.wikipedia.org/wiki/Clutch |
"Smart" alternator control is a valid approach - it's been used (and is being used) on many models. BMW comes to mind, with its "efficient dynamics" program.
I am sure they thought of that eventuality and put in a low volt threshold for the alt cut in.
OP -
Do you ever do any engine braking? You might try to figure in a circuit that allows the alternator to charge during engine braking as well. |
I posted something about a system I developed to do this that works on injector duty cycle (when in deceleration its at 0% so switches the alternator on at this level only) and also a battery voltage switch that prevents the battery becoming too discharged.
http://ecomodder.com/forum/showthrea...king-1391.html |
Woudn't just one relay on the field circuit accomplish the same thing without the heavy duty relay which the output circuit would require? A simple circuit to disable this when the headlights are on would probably be enough to eliminate the dead battery worry.
I found on my 4x4 that when crawling down a steep hill, that turning the AC on helps keep my speed under control. the ac is just enough to hold me back...
Makes sense it would work for the alternator... Dave |
