View Poll Results: What should I do? 2000 Dodge Neon
Stick with auto tranny but weld into highest gear. 0 0%
convert to manual tranny. 3 50.00%
convert to direct drive to the axles in the front. 1 16.67%
convert to rear wheel drive with a donor cars rear end and couple motor directly to differential. 2 33.33%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Old 01-21-2009, 01:18 PM   #1 (permalink)
Arrow Deciding on a drive train...
2000 Dodge Neon, originally FWD. Should I...
Old 01-21-2009, 02:37 PM   #2 (permalink)
What is your goal here? Obviously not saving money lol. If you wanna make the most of what you got, go for it. If you wanna take a small step and upgrade to a manual tranny for P&G you'll see substantial gains. If you want to make a hybrid I say go for it. Of course I'd like to see a hybrid like that so I'll say hybridize it.
Old 01-21-2009, 05:57 PM   #3 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Sooner or later you have to decide what is your goal. Just saving money or high MPG. You can trade you fuel sipper for a dirt-cheap gas hog and it will reduce your payment so much (assuming your vehicle isn't paid for) that you'd have to drive to the moon to save fuel $$$ enough to offset up-front cost. That is particularly true now. You can get SUVs for scrap prices now. I even saw a Mercedes 6.9 for $2,000. Yeah, it only gets 10 MPG but 2 grand is dirt cheap and it probably will go back up in value. Hint: There's one in Jay Leno's garage (then again, what isn't?)
To me the MPG bragging rights have become a goal of their own.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 01-21-2009, 06:16 PM   #4 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
The automatic tranny will actually work to your advantage if you're using an electric motor, given the weight of your chassis, especially if you're using a smaller motor than what would normally be used. It provides a variable set of gears that allows the motor to run in a higher power profile for longer per gear.
If you're not switching to and electric drive system, then you really do need to figure out what your goals are exactly. The RWD conversion for a Neon is not a new topic, in many street performance circles. To do it with an e-motor, you'd be better off using a FWD drivetrain and mounting it transversely, or using the rear setup from a VW Bug.
Hybridizing a 2-wheel drive pickup bennelson EcoModding Central 5 10-14-2008 11:53 AM
Drive Slower or Drive Faster behind a Semi? Which is more efficient? izanti General Efficiency Discussion 9 08-06-2008 04:43 PM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
Front VS Rear drive on electric bennelson Fossil Fuel Free 18 02-03-2008 03:10 PM
