Old 12-02-2011, 05:59 PM   #1 (permalink)
grins2go_brett's Avatar
Velcro to attach Coroplast grill block?
Living in the desert area of Phoenix, AZ, I have to remove a lot, if not all of my grill block in the summer time. I have it cut into many sections so I can remove relatively small pieces as the temps rise in the spring, and put them back on in the fall. I've used duct tape so far, but want/need something a little cleaner and easier to remove, and less noticeable. I was thinking of using some Velcro to attach it to the grill. Has anybody tried using Velcro before, and if you have, what were your results? Thanks!
Old 12-03-2011, 12:07 PM   #2 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Unless you sew the Velcro on...the adhesive on the back of the Velcro will let go under the heat.
Mechanical fasteners are the way to go. Clips, screws, snaps, zipties, etc...
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 12-03-2011, 12:44 PM   #3 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
Use small/thin zipties (cable ties) easy to put on and cheap. cut them off when you don't need the grill block
