Old 03-09-2010, 02:40 PM   #1 (permalink)
sukisuki - '00 Suzuki Grand Vitara 4wd
90 day: 21.88 mpg (US)
New injectors?
Technology Review: Ultra-Efficient Gas Engine Passes Test
Transonic Combustion, a startup based in Camarillo, CA, has developed a fuel-injection system it says can improve the efficiency of gasoline engines by more than 50 percent. A test vehicle equipped with the technology gets 64 miles per gallon in highway driving, which is far better than more costly gas-electric hybrids, such as the Prius, which gets 48 miles per gallon on the highway.
The key is heating and pressurizing gasoline before injecting it into the combustion chamber, says Mike Rocke, Transonic's vice president of business development. This puts it into a supercritical state that allows for very fast and clean combustion, which in turn decreases the amount of fuel needed to propel a vehicle. The company also treats the gasoline with a catalyst that "activates" it, partially oxidizing it to enhance combustion.
high voltage injectors (HDi diesel) ecoxantia OpenGauge / MPGuino FE computer 54 01-15-2010 11:12 AM
Nissan aims for "more complete burn" with new injectors MetroMPG General Efficiency Discussion 14 07-19-2009 08:47 AM
Duty cycle of fuel injectors Gregte DIY / How-to 9 05-22-2008 09:21 PM
D15Z1 injectors? StorminMatt EcoModding Central 4 02-08-2008 06:46 PM
Better injectors for better FE tasdrouille EcoModding Central 6 01-31-2008 05:29 PM
