EcoModder.com
-   -   which diesel engines rotate clockwise? (https://ecomodder.com/forum/showthread.php/diesel-engines-rotate-clockwise-15497.html)
IsaacCarlson 12-16-2010 07:54 PM
I am looking for a diesel engine for my truck and can't seem to find one that rotates clockwise. Some that I have found don't even say which direction.
Any help would be appreciated. 4-6 cylinders, preferably less than 1,000 lbs.
About 100 HP would be good. Lots of torque is always a plus.
d0sitmatr 12-16-2010 07:59 PM
for the f-250 or a different truck ?
IsaacCarlson 12-17-2010 12:30 AM
for the 250.
d0sitmatr 12-17-2010 12:46 AM
well, you could possibly look at some toyota diesels. the ones Ive come across are 4.3L 6cyl.
although I dont know their rotation, they are for RWD vehicles, they are also pricey.
Ryland 12-17-2010 10:27 AM
Search Results
Conrads auto salvage (about 10 miles away from you) has a diesel core with no heads that bolts in to an F-250.
UFO 12-17-2010 11:46 AM
I don't know of any that don't rotate clockwise. But it sounds like you might be happy with the CRD engine from a Jeep Liberty. 2.8 liters, 295 ft-lbs, 163 hp. It works amazing in my Jeep, about 4500 lbs.
DonR 12-17-2010 12:16 PM
I think the Cummins 4bt's rotate that way. I don't have to change anything to drop one into the YJ.
Cummins 4BT & Diesel Conversions Forums
fordcummins.com - Increase Horsepower with Ford Cummins Diesel conversion kits
Sorry, I think the last one is a commercial site.
DamageX 12-20-2010 03:53 AM
direction of rotation as viewed from the transmission side or from the engine side?
vacationtime247 12-20-2010 04:45 AM
Looking at the front of the motor, the belts and pulleys will rotate clockwise. There are only a few engines that run counter-clockwise (such as in boats to reverse and planes with propellers) 6.9 idi turbo diesel? What engine does it have now being an F-250, the 302 5.0 or 5.8 351W? A 87 6.9 liter idi with an ATS turbocharger backed by a ZF 5 speed and some proper rear gears would be sweet! Should be an easy bolt in too. Swapping in a different engine from a different manufacturer would cause issues. Mounting the engine and transmission, plumbing exhaust to not hit the new mounts, getting the proper driveshaft / transmission angle correct, routing the accessory drives (alt, water pump, power steering) etc. Put a 350 Chevy Vortec & 700R4 into a 1987 Toyota Supra, there's alot involved with a hybrid.
VT247
IsaacCarlson 12-20-2010 11:19 AM
It has the 4.9L I6. It rotates clockwise on the flywheel.
