Old 09-13-2013, 09:14 PM   #1 (permalink)
The Truck - '02 Nissan GU Patrol ST
Diesel intake restriction reduces efficiency.
Just came across this study:
http://www.icrepq.com/ICREPQ'09/504-mamat.pdf
Conclusion
The results show that the pressure drop in intake
manifold gives negative impact not only to the engine
efficiency and power density, but also in terms of engineout
emissions.
The Following User Says Thank You to Tesla For This Useful Post:
Vekke (09-14-2013)
Old 09-13-2013, 10:23 PM   #2 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
Cold Air and Ram Air - EcoModder
Seeing how more air helps FE for diesels, the opposite should be true for less air.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
