Old 11-09-2011, 04:40 PM   #11 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by UFO View Post
We are not talking about over-extended change intervals, the test oil was 5k miles, within a normal change interval. Anti-oxidation additives will certainly last that long. I've had oil tested at 10k miles with nothing out of spec, so I doubt you can make the claim the oil lubricity is significantly changed in 5k miles, or 10k for that matter.
But I can make the claim that it had particles of soot and metal in it which contributed to the wear in the test.
Old 11-09-2011, 05:14 PM   #12 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
I'd like to see that. A typical oil analysis, like this one,
measures contaminants in single and double digits ppm. Make the case, but I am doubtful of this potential cause of wear as well.
I'm not coasting, I'm shifting slowly.
Old 11-10-2011, 02:02 PM   #13 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
Look into one of these
Red Line Synthetic Oil - Diesel Fuel Additives - Diesel Fuel Catalyst
Schaeffer Oil | Diesel Fuel Additives, Stabalizers, Conditioners, Treatments
The Following User Says Thank You to DonR For This Useful Post:
larrybuck (11-10-2011)
Old 11-10-2011, 09:41 PM   #14 (permalink)
I take some of these results with a grain of salt but it will add some insight into the discussion.
Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums
The Following User Says Thank You to Duffman For This Useful Post:
larrybuck (11-11-2011)
Old 11-10-2011, 10:04 PM   #15 (permalink)
90 day: 19.36 mpg (US)
Can't go wrong with any product by Schaeffer's.
Stanadyne is the default additive otherwise.
The Following User Says Thank You to slowmover For This Useful Post:
Old 11-10-2011, 10:22 PM   #16 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
larrybuck:
You need to check out The Diesel Page - for the 6.2L, 6.5L, and Duramax 6600 (6.6L) GM Chevrolet and GMC diesel engines.
They have a mountain of information you need to check out.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
