Old 05-17-2011, 10:13 AM   #11 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
The VAG AHU TDi is 89hp and 149tq...
The BMW 2.4 is 114hp and 162tq, and will probably cost twice as much, and weigh more as well.
That power or more can be made perry easily from the AHU, which will be very easy to get from a wreck in Canadia.
I still want to make a trip to michigan so I can find an AHU "buried in the field"...
Lol.
Old 05-17-2011, 10:25 AM   #12 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Not bad for the AHU. I just figured the length would be a little closer to what is already in the car.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 05-17-2011, 10:50 AM   #13 (permalink)
Isn't BMW part of VAG? Makes sense that a 25% larger engine of basically the same design would make around 25% more power.
Old 05-17-2011, 10:57 AM   #14 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
No, they're independent.
Old 05-17-2011, 10:58 AM   #15 (permalink)
Can't keep track of who's buying who these days...
Old 05-18-2011, 03:11 PM   #16 (permalink)
just picked up the book jag that run.
nice thing about the chevy conversion is that they have been done before.
While yes - a 1.9 would secure high mileage, the above gets a few points with me.
my 120 mile commute to work is all country highway, therefore not to concenerned if it is a bit underpowered. If I want power, I have the other car.
I would imagine the 1.9 would have lots of room in there!
Old 05-18-2011, 03:25 PM   #17 (permalink)
2002 Jetta TDI with the 1.9 in it comes in at 2970 lbs
1000 lbs differential if I were to go this route - unsure the weight difference in the engines, but one would think the engine is lighter.
Old 05-18-2011, 04:28 PM   #18 (permalink)
The full dress weight of the TDI comes in at 297 pounds. The engine that you have is 531 pounds, plus the weight of the transmission. So depending on what transmission you run behind the VW unit, you might lighten the car up quite a bit. The 6.2/6.5 weighs about 700 lbs. ( still undercuts the BB Chevy by 40 lbs. ).
The main consideration will be dealing with the electronics. The 6.2/6.5s are by and large mechanical, except for the 6.5 turbodiesel that has the electronic Stanadyne DS4 pump ( these pumps have been maligned because of the location of the PMD. This thing gets hot and causes stalling problems. Move it to a cool location with a PMD relocator kit and all is good. ).
Old 05-18-2011, 10:23 PM   #19 (permalink)
Easter McoModder
SwamiSalami's Avatar
'99 Subaru OLL 2.5L - '99 Subaru Outback Legacy Limited
90 day: 22.57 mpg (US)
Rabbit - '08 VW Rabbit S
90 day: 32.93 mpg (US)
Yes. As I said before 1.9.
I don't understand why I'm the only one being second guessed here.
Old 05-18-2011, 10:41 PM   #20 (permalink)
The 1.9 is by and large a stand alone system.
Sure there's wiring, but its only a few sensors and some injector trigger wires. 30 wires, maybe?
You don't even have to tap it into the Jag harness, you can leave the two parts separate from each other.
The AHU only has one engine mount, on the front. A bar could be made to stabilize it across the longitudinal engine bay, or bosses might be found on each side of the motor to mount it.
Big Dave's favorite suggestion is a T56 trans, which has a double over drive ratio. The 1.9 may need a little massaging to pull 62mph @ really low rpms, because it doesn't get into the good boost until 1400+rpm.
I think the target rpm for the 1.9 should be about 1300rpm @55-60mph. With a nice exhaust and intake, and a good tune on the motor, it should be do able.
I look forward to seeing this done.
