Old 04-09-2011, 11:10 AM   #61 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
It was a4 speed, and I don't have it any more, but I'll check if I can find them.
Old 04-09-2011, 11:19 AM   #62 (permalink)
Gear Ratios: Primary reduction 3.833:1, First 2.769:1, Second 1.722:1, Third 1.272:1, Fourth 1:1, Final reduction 15-35 2.333:1
That seems right.
Old 04-09-2011, 11:33 AM   #63 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
what is the radius of the rear wheel, from the centerline of the axle to the ground?
Also 2.769 (2.769/1) is better than 2.44 (for a flat torque curve like a diesel or an electric)
Old 04-09-2011, 11:39 AM   #64 (permalink)
Its a 3.5/16 tire oe.
I thought the longer gears should be better?
Also, I'll probably have to replace those tires soon... Good 16" tire recommendations?
I could get some touring pedal bike tires from wally world... Lol.
Old 04-09-2011, 12:57 PM   #65 (permalink)
dcb
needs more cowbell
dcb's Avatar
what is the outside circumference of a 3.5/16 tire?
I think a wider spread ratio from 1st to top gear is best for fairly flat torque curve engines like your clonemar (or an electric motor).
Old 04-09-2011, 11:16 PM   #66 (permalink)
I'll measure when I get a chance tomorrow.
Old 04-10-2011, 08:47 PM   #67 (permalink)
3.50x16 falls between 100 and 110/90-16. Center to edge was about 11.4 inches.
Old 04-10-2011, 08:56 PM   #68 (permalink)
Easter McoModder
SwamiSalami's Avatar
'99 Subaru OLL 2.5L - '99 Subaru Outback Legacy Limited
90 day: 22.57 mpg (US)
Rabbit - '08 VW Rabbit S
90 day: 32.93 mpg (US)
I think that Jesus would've driven a diesel motorcycle.
Old 04-10-2011, 09:08 PM   #69 (permalink)
dcb
needs more cowbell
dcb's Avatar
lol, actually the "i" is short, as in Kristy McNichol, I think
ok, 11.5 inch radius for the rear wheel, about 877 revolutions per mile. Good to know.
Old 04-10-2011, 09:15 PM   #70 (permalink)
Yes, it's Christ, like Crystal, but without the "ull" sound.
So I measured that twinstar frame up a bit today... The motor won't fit with a transmission behind it, unless it's a 90°turn, so the motor/trans is longitudinal, and the output still transverse to the frame.
Strangely enough, I have a drive converter that does exactly that. Gonna have to measure more.
