Old 05-19-2011, 02:38 PM   #1 (permalink)
...beats walking...
...a DIM LAMP question!
Q: if I know the maximum, aero-limited vehicle speed (124 mph) and the engine RPM at that speed (4,800 rpm), and the calculated horsepower output at that engine speed (135hp = 148lbft × 4800rpm/5252), shouldn't I be able to "back-into" other such variables as:
1) Engine efficiency (~0.23)
2) Drivetrain efficiency (~0.95)
3) Coefficient of Drag (Cd ~0.33)
...so as to obtain a "better" estimated MPG, using the EM calculator?
...I just plugged in the following numbers for our 2011 LTZ and got a calculated 110 hp value at 124 mph, which is too low:
• Vehicle weight = 3500 lbs (my guess: 3177 lbs curb + 323 lbs load)
• Crr = 0.009 (my guess)
• Cd = 0.33 (working backwards from 0.298/0.9 from GM)
• A - Frontal Area = 24 sg.ft. (from brochure dimensions)
• Fuel Density = 33557 (summer blend)
• Engine efficiency = 0.23 (a guess)
• Drivetrain efficiency = 0.95 (default value)
• Parasitic overhead = 0 (default value, what for A/C being "on"?)
• Air Density = 1.164 @ 86ºF (yes, this is the desert)
...both C&D and R&T magazines have published 124 mph as the 'tested' aero-limited top speed for the 2011 Cruze LTZ 1.4LT with 6-speed automatic.
...comments or suggestions or "±" critiques?
NOTE BENE -- the "DIM LAMP" reference is a tongue-in-cheek nod to "...light's ON, but only DIMMLY lit..." meaning I've got a half-baked idea, so do I keep cooking or turn the light full out?
Old 05-19-2011, 03:32 PM   #2 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
I'm pretty sure the drivetrain efficiency is too high. Try 85% for a stick, or 80% for auto.
Paracitic,
between 2000 and 5000 (guestimate) for A/C,
probably at least another 100+ for engine management
Mechanical fan? 1500+
Old 05-19-2011, 05:03 PM   #3 (permalink)
EcoModding Lurcher
mort's Avatar
I'll add that your rolling resistance can only be that good on really good road with the best tires. I don't think a race track would qualify. Try .015 at least.
-mort
Old 05-19-2011, 05:26 PM   #4 (permalink)
...beats walking...
...the Goodyear RS-A's on my 2009 Vibe are listed as 0.00918 ~ 0.0092 in the 2005(?) NHSTA tire booklet.
...the Michelin Pilot's on our 2011 Cruze are 'supposed' to be better (?) than the Goodyear RS-A's, hence my "guesstimated" 0.009 value for the Pilot's (at 40 psi, not 30 psi).
Old 05-19-2011, 05:40 PM   #5 (permalink)
TheEnemy's Avatar
You might be pretty close, I was playing with it, and noticed that when I adjusted the drivetrain efficiency it only affected the FE calculation, so the HP figure given is at the wheels, not at the flywheel.
so 110hp/0.8 = 137hp at the flywheel
Old 05-19-2011, 07:21 PM   #6 (permalink)
...beats walking...
...Thanks! I should've thought of that (ie: flywheel HP vs. driven-wheel HP) but, obviously, didn't.
