Go Back   EcoModder Forum > AltModding > Saving@Home
Old 03-08-2010, 04:23 AM   #11 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
good point about integration, but component wise it means basically a diode and a capacitor, I think, for the inexpensive-get you within a few %-version.
Old 03-08-2010, 04:29 AM   #12 (permalink)
24.27 lbs per gallon Co2
Oval_Overload's Avatar
Unicorn - '12 Nissan Versa 1.8S hatch
90 day: 31.9 mpg (US)
Researchin's highlighted my naïvety:
Basically a current transducer generates a current or voltage (depending on the type) that is proportional to the current passing through the center of the transducer. There is a slight complication however. You can't just clip one of these around a piece of romex wiring since it contains both legs of the circuit. Since the current going out on the hot wire is equal to the current returning on the neutral wire, they will cancel each other out and the transducer will read zero.
Ecomodding: I'm doin' it wrong.
Source: Circuit Monitoring
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
Old 03-08-2010, 04:52 AM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
yah, the mains are usually separated though, but I wouldn't hang c-clamp bolt threads on them, they deserve a *little* more care than that.
Also dissecting an extension cord so you can get to a lead is possible, but the individual appliance thing has been done. I think we want whole house next.
you could shut off the main circuit breakers, and wrap the two legs (not neutral) of the mains in wire (do try not to kill yourself, get some inexpensive thick rubber gloves from the home improvement store, etc. <insert long list of caveats and precaution>, etc.) and see what the voltage reading looks like on those coils. Also you want to monitor system voltage on both legs.
Old 03-08-2010, 12:53 PM   #14 (permalink)
I think I'm going to carry out the experiment on a hacked extension cord before I go futzing with the 200 amp service. However, I think there is plenty of room in the distribution box box to place a sensor.
~Jimbo
Old 03-09-2010, 06:09 PM   #15 (permalink)
The basic integrator is an opamp and a few resistors and capacitors. Designing it to be accurate is not that easy. Hall effect is simply the superior way to sense current.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 03-09-2010, 06:34 PM   #16 (permalink)
dcb
needs more cowbell
dcb's Avatar
yes, a clamp on hall is simple, just a pain shopping for the "right" one to figure out the additional costs/sensitivity, as compared to the simplicity of x number of turns of small gauge y wire around diameter z mains wire. I don't think an opamp is even a requirement. Figure you can sample 4 readings (2 leg currents and 2 leg voltages) at 5khz with a atmega168 anyway, with or without a hall.
Old 03-09-2010, 08:41 PM   #17 (permalink)
dcb
needs more cowbell
dcb's Avatar
sanity check, wrapped a small jumper around a leg and hooked up a vom on AC. with 5 complete turns it was reading 1.2-2.5 mv, so not a whole lot of signal, with only 5 turns. no guess how many amps that represents nor what a usable minimum value for aref on the atmega is.
Old 05-11-2010, 05:51 PM   #18 (permalink)
Have a look at the open energy monitor
OpenEnergyMonitor ( i cant post links)
Arduino
+ Current clamps (for current sensing-- I'd get the CR3110 from digikey)
+ AC-AC transformer (for voltage sensing - -I'd try ebay?)
+ cheap stuff such as capacitors and resistors
= Energy Monitor
Old 05-12-2010, 01:44 AM   #19 (permalink)
Home | OpenEnergyMonitor
Old 05-12-2010, 09:01 AM   #20 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Black and decker makes an electrical monitor that clamps on to your electric meter on the outside of your house, it costs $75-100 depending on the store or ordering it online.
http://www.blackanddecker.com/energy/products.aspx
I realize this page was started for the do-it-yourself build, but why reinvent the wheel? this unit looks like it would work and be accurate.
The Following User Says Thank You to Ryland For This Useful Post:
Oval_Overload (05-12-2010)
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
New 1/2 house A/C time dremd Saving@Home 16 06-17-2010 10:11 PM
Monitor real time energy usage with Google Cd Saving@Home 18 09-18-2009 09:24 PM
Geothermal energy? DifferentPointofView Saving@Home 46 02-05-2009 10:15 PM
