Old 05-27-2008, 04:34 PM   #1 (permalink)
SirKeats's Avatar
GeRide - '89 Geo Metro *XFi
90 day: 54.26 mpg (US)
How to test O2 Sensor?
Is there a way to test to make sure my O2 sensor is working properly... or given that I have no history on my recently purchased 89 metro, should I just assume it needs to be replaced?
Old 05-28-2008, 10:42 AM   #2 (permalink)
ttoyoda's Avatar
Well the 2 ways I know of on toyotas:
With the car warmed up, rev the engine and measure the voltage between the O2 sensor output and ground. It should oscillate several times a second as the engine overshoots and undershoots the "correct" fuel-air ratio.
The other way is to take it out, and measure the voltage on the output wire while heating just the sensing end of the sensor with a propane torch. You should see a voltage output, because, as far as I understand it, the O2 sensor is a battery which is powered by O2 concentration *differences* between the sensing end, and the "outside the exhaustpipe" end. Which is why those little holes are drilled in the side of the outside end: gives access to the atmospheric O2 concentration.
There is a O2 sensor problem that I don't think either of these tests will find, and that is when the O2 sensor develops a voltage offset which skews all the readings high or low.
Old 05-28-2008, 12:06 PM   #3 (permalink)
Pushrod - '02 Chevrolet Cavalier
If there's a problem, it will be obvious. A CEL will go off, it will run like garbage, and/or stink of gas.
Old 05-28-2008, 12:25 PM   #4 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
When measuring the voltage use a high impedance volt meter(20megohms).
The voltage signal is usually between 0.2 and 0.8 volt DC. 14.7 to 1 air/fuel is somewhere between 0.3 and 0.6 VDC. So the sensor is so touchy in the midrange that all it can do is switch between rich and lean. <0.3 lean and >0.6 rich.
The two white wires are the heater prw and grnd.(Ford)
The gray is signal and the black is signal grnd on a 4 wire Ford.(Bosch)
Johnny do you have the wire colors on other brands? Also is it correct to say that a failing sensor would put out less voltage?
Test: F-150 pickup "cap on" vs. "cap off" @ 60 mph MetroMPG Aerodynamics 17 11-17-2011 01:44 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
My Kingdom for a NOx Sensor cfg83 EcoModding Central 19 08-25-2010 06:55 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Perhaps honda specific: Will a code 41 (o2 sensor heater) tank my mileage? SVOboy Off-Topic Tech 13 08-04-2008 09:35 PM
