Old 12-19-2011, 12:39 AM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
diy two speed gearbox
found a site where the double chain gearbox is pretty well spelled out, a couple extra chains might be avoided if you have two sprockets on the rear wheel/axle, and/or can drive the input shaft directly. Anyway it might offer some ideas for small EV'ers to be able to climb hills AND have decent top speed (and a neutral) hopefully without the losses of a belt/pulley.
Widdershins Way - DIY Gearbox
Old 12-19-2011, 09:34 PM   #2 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Warning ! Thread hi jack !
I recently learned some folks are using transfer cases backwards to make a poor mans overdrive unit.
Anyone here try it ?
From pull-a-part I could do it for ~$100 on my truck....
Bet it would work great on an EV
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 12-19-2011, 10:13 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
might be a bit over-engineered for a typical ev=lossy.
