11-20-2021, 08:24 AM
Mat & Carpet Removal
Hi Ecomodders!
Please, tell me that I should not do this and should not even think about this anymore!
I want to remove floor mat like they do in race/drift cars.
Something like like this:
(Photo from https://svgmotorsport.com/about-the-...-car-interior/)
But it has several drawbacks:
1. Much more noise (will I need earplugs like on a helicopter?).
2. Hotter in summer (A/C may consume much more which will have negative impact on FE).
3. Colder in winter.
4. Vibration. (Thanks to freebeard!)
Please, post photos of your interior if you did the same.
And tell your opinion on the real noise feeling, temperature, etc.
Or even may be there other issues that I'm not aware?
11-20-2021, 12:46 PM
Not so extreme, plus much of the noise would come from a lower spot. Did you notice ambulances and police cars now feature the sirens behind the front grille instead of above the roof? That was done in order to decrease the likelihood of long-term hearing impairments for operators.
You could eventually resort to some thermal insulators which are lighter than the original trim. Those aluminium-sided insulator blankets, often used for roofing insulation, are quite common to see on JDM cars converted from RHD to LHD in countries such as Paraguay, sealing some gaps on the right-hand side of the firewall.
Colder in winter.
Either those aluminium-sided blankets or some rubberized paint could do the trick to not make the interior so colder in winter.
11-20-2021, 01:25 PM
Both of these had bare floorboards but I don't have a picture of the interiors.
These work because of the rear engine. No fumes in the cabin or exhaust heat.
The thing you didn't list is vibration. You sit with your feet on a drumhead.
.You can't be wise and in love at the same time. -- Bob Dylan
11-20-2021, 01:47 PM
Too many cars
I have a bare metal floor in my Insight. No carpet, no under-carpet sound deadening. I took the carpet out to wash it. I haven't put it back in because I have a few water leaks to fix first. Yes, it's loud and I wear earplugs.
The carpet in this small car was under 6 pounds. The tar sheets under it were at least that much.
I'm not sure how much it affects temperatures in the car. A floor mat in winter might help.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
11-20-2021, 02:18 PM
I afraid, this is not the good idea, as I also want to keep nice look of the interior.
Those insulators should be covered with something, but it means literally yo return carpet back.
11-20-2021, 02:20 PM
I think, I will definitely keep mats. First of all we have dirty winters... Second is that I want bare metal to be protected from scratches and quick rust.
11-20-2021, 02:30 PM
Do you wear earplugs BECAUSE OF that noise? Is it really so loud?
I'm expecting much noise comes from the road and wheels, not the engine.
Does engine really produce more noise?
11-20-2021, 02:40 PM
First of all we have dirty winters... Second is that I want bear metal to be protected from scratches and quick rust.
https://www.thesamba.com/vw/gallery/pix/644729.jpg
I should make up a set of these for my Baja Bug.
11-20-2021, 03:16 PM
#9 (permalink)
Too many cars
It's mostly road/tire noise. I also have no rear interior, so I get a lot of noise from the rear tires. If you take out only the carpet, but leave the floor mats, it might not be that bad.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
11-20-2021, 05:10 PM
#10 (permalink)
No picture, but successive Beetles have had an L-shaped deck to replace the shotgun and rear seats. Six feet long by 4 feet wide. It's about six inches off the floor. Probably quieter than having the seats.
Carpeted now but it was raw plywood for a long time because I would move air compressors and stuff in it.
