Mat & Carpet Removal
Hi Ecomodders!
Please, tell me that I should not do this and should not even think about this anymore! :D I want to remove floor mat like they do in race/drift cars. Something like like this: https://svgmotorsport.com/wp-content...r-Interior.jpg (Photo from https://svgmotorsport.com/about-the-...-car-interior/) But it has several drawbacks: 1. Much more noise (will I need earplugs like on a helicopter?). 2. Hotter in summer (A/C may consume much more which will have negative impact on FE). 3. Colder in winter. :( 4. Vibration. (Thanks to freebeard!) Please, post photos of your interior if you did the same. And tell your opinion on the real noise feeling, temperature, etc. Or even may be there other issues that I'm not aware? :eek: |
Both of these had bare floorboards but I don\'t have a picture of the interiors.
https://ecomodder.com/forum/member-f...-outa-town.jpg These work because of the rear engine. No fumes in the cabin or exhaust heat. The thing you didn't list is vibration. You sit with your feet on a drumhead. |
I have a bare metal floor in my Insight. No carpet, no under-carpet sound deadening. I took the carpet out to wash it. I haven't put it back in because I have a few water leaks to fix first. Yes, it's loud and I wear earplugs.
The carpet in this small car was under 6 pounds. The tar sheets under it were at least that much. I'm not sure how much it affects temperatures in the car. A floor mat in winter might help. |
Those insulators should be covered with something, but it means literally yo return carpet back. |
I'm expecting much noise comes from the road and wheels, not the engine. Does engine really produce more noise? |
https://www.thesamba.com/vw/gallery/pix/644729.jpg I should make up a set of these for my Baja Bug. |
No picture, but successive Beetles have had an L-shaped deck to replace the shotgun and rear seats. Six feet long by 4 feet wide. It's about six inches off the floor. Probably quieter than having the seats.
Carpeted now but it was raw plywood for a long time because I would move air compressors and stuff in it. |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
