Old 05-17-2012, 10:26 PM   #1 (permalink)
S197 - '07 Ford Mustang GT
90 day: 27.42 mpg (US)
Do we need hubs?
With the right alloy wheel, why not machine the center and press in bearing races?
Crappy MS Paint picture of my idea: ('Wheels' to the left)
As I was thinking about making a floating axle hub for a project I'm developing, I got to thinking, "Why bother with a hub?"
Besides, the obvious benefit of speedier tire changes; why not do away with it? Why not make the wheel, hub, and rotor hat one piece? There's several pounds of sprung weight and rotational mass shed right there.
Old 05-17-2012, 11:28 PM   #2 (permalink)
So you want to integrate your brakes into the wheels then?
Old 05-17-2012, 11:41 PM   #3 (permalink)
JellyBeanDriver's Avatar
That and the bearings are usually located in the centerline of the tires to minimize loading
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
- http://www.dschmidt.com/MPGuinoJBD.html
Old 05-18-2012, 11:11 AM   #4 (permalink)
SCNTN's Avatar
SC1 - '02 Saturn SC1
Team Saturn
90 day: 41.8 mpg (US)
DaGnoma - '02 GMC Sonoma SL
Pickups
90 day: 25.03 mpg (US)
Getting those disc calipers off would be a total PITA. Drum brakes however...
Go Team Saturn!
Coming soon... aero accessories by LowCd!
Old 05-18-2012, 11:11 AM   #5 (permalink)
I would hate to have to replace my wheels every time my brake discs need machining, or try to figure out how to machine the integrated disc... unless we went back to the brake shoe directly acting on the outside of the tire
Work From Home mod has saved more fuel than everything else put together.
Old 05-18-2012, 11:34 AM   #6 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
why not perfect electronic braking and eliminate the rotor entirely?
Old 05-18-2012, 02:41 PM   #7 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
VW has the wheel bearings pressed in to the rear brake drum and it makes them a pain to deal with, a side effect is that the rear brake drums have to be replaced more often because the brake shoes wear out and score the drums beyond repair because the shoes were not inspected as often.
Other cars where the drums are held on by the wheel being held in place are easy to check the brakes when rotating tires or changing from summer to winter tires, so I could not imagine how annoying having the wheel bearings pressed in to the wheel would be.
Old 05-18-2012, 02:45 PM   #8 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Look ma! No hubs!
I'm not coasting, I'm shifting slowly.
Old 05-18-2012, 03:20 PM   #9 (permalink)
PSmodder lurker
I'll see you, three hublesses,...http://sbarro.perso.neuf.fr/voitures...Aero_Paris.jpg
...make that four hublesses.
Old 05-18-2012, 03:59 PM   #10 (permalink)
...beats walking...
...with: motor / generator = power / braking (regeneration!)
The Following User Says Thank You to gone-ot For This Useful Post:
taco (05-19-2012)
