Old 09-29-2010, 11:39 PM   #1 (permalink)
Meph's Avatar
240Z - '73 Datsun 240Z 240Z
90 day: 34.41 mpg (US)
Does Fuel Degrade Over Time?
I always assumed that fuel degrades over time, having a half life time of some kind. I have a 16 gal fuel cell i tend to top up ever time It drops 4-5 gallons, so I can check my mileage and keep weight over the rear wheels.
If I top up ever few weeks, there would be some percentage of fuel in the tank from months ago. Wondering how potent that gas still is, and if it could be hindering my numbers.
Old 09-30-2010, 03:22 AM   #2 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
depends on the blend. Ethanol is hygroscopic if the tank gets condensation inside the water will end up in the ethanol and a portion of the volume will be water.
When I lived in the bush the fuel delivered was a more stable blend because we would get one fuel barge before the river froze and the fuel had to be stable enough that it would be in good shape till spring and the next barge could get there.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 09-30-2010, 09:37 AM   #3 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
As I understand it gasoline has a shelf life of 6 months before it starts to degrade enough to cause any problems, gasoline with eithonal has a shelf life of about 3 months.
As it ages the octane rating drops and the volital part of it dissipates as well, I've been told that Leaded gas, like air plane gas has a much longer shelf life of a year or more.
Old 09-30-2010, 10:00 AM   #4 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
You might want to run your tank down to almost empty periodically to use up the "old" gas and assure that you have fresh stuff in there. Or use a preservative like Sta-Bil.
Old 09-30-2010, 12:27 PM   #5 (permalink)
...beats walking...
...that's a VERY interesting question, to which I can personally relate an answer!
...back in 1969, while flying in USN, we flew down to Acapulco, Mexico, to chase a tropical hurricane; the only problem was the only AVGAS (115-145 purple) they had there was left over from WWII and it had slimey green algae growing in it (and entrained water)! So, we had to "filter" every gallon pumped from their tanks through 'chamois' skins...and our EC-121 Super Connie held 8,758 gallons of gas!
...don't know how "long" that gas had been sitting, but from 1945 to 1969 is 24 years. The gas (after straining) was basically 99% usable, as the flight engineer said he only had to slightly back off on the ignition advance during METO power at take-off.
...by 1969 the Acapulco airport was handling only jets.
Old 09-30-2010, 08:07 PM   #6 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Meph View Post
I always assumed that fuel degrades over time.
It does, but it's going slowly.
Whenever my bike stood still for months on end (even up to a full year), it had a full tank of "old" fuel to start with. I've never had any problem with the fuel nor with the carbs.
Old 09-30-2010, 08:19 PM   #7 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
I work at a powersports shop in my free time. We run into more fuel related problems then you can imagine. To get rid of lead in fuel, they had to include other additives. Olefins settle out and degrade, forming a waxy varnish layer on the parts making content. Olefins, if I remember correctly, are what determine the knock rating of a fuel. I could be wrong, so a more credible source would be great.
Old 09-30-2010, 08:43 PM   #8 (permalink)
Ryland's Avatar
I've also worked at a motorcycle shop and every spring people bring their motorcycles in that worked in the fall, half of them need nothing more then fresh fuel.
Old 09-30-2010, 09:30 PM   #9 (permalink)
I wish it were only half by us. But we have ethanol.
Old 09-30-2010, 09:55 PM   #10 (permalink)
Niner_xA - '05 Scion xA
90 day: 35.82 mpg (US)
Horse Hauler - '95 Ford F-250 XLT
90 day: 13.47 mpg (US)
Butterkup - '02 Mazda Miata
I had a generator sitting in my garage for a year. I meant to exercise it regularly, but we used to lose power pretty often (snow in the winter; wind in the spring and fall) so I wasn't vigilant. This fall when we lost power, I realized it had been at least a year since I touched it. Luckily, I was good about putting Sta-bil in it, and it fired up without any problems.
That said, if I were using fuel, I'd try to drain the tank as much as possible. That makes the age of fuel cut off very sharply after the length of time between fillups.
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
As I Had Thought Big Dave General Efficiency Discussion 54 09-02-2008 11:00 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
