Old 07-20-2009, 03:03 PM   #21 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by bombloader View Post
Are you referring to the case of carbureted engines? Most non-aviation carbureted engine have fixed jetting for mixture, so yeah efficiency does decrease because the mixture becomes richer. You have to rejet the whole carburetor to fix the problem. Modern injected engines maintain a stoichometric mixture constantly, so that wouldn't be a problem.
Trapped mass due to egr plays a role as well. At part throttle at low altitude you have more egr in the cylinder than you would at a higher altitude forthe same amount of fuel burned. The egr absorbs some of the heat of combustion that would otherwise be transferred to the engine block. This allows that heat to be converted to work instead of being dumped through the radiator.
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
