Old 04-27-2009, 11:32 AM   #1 (permalink)
In persuit of Efficiency
zman's Avatar
Bouble - '01 Toyota Echo 2 door
90 day: 41.62 mpg (US)
Door gap reduction using neoprene tubing
Low cost aerodynamic improvement to reduce the air turbulance of gaps aroud doors, hood and trunk is to cut a neoprene tubing of the correct diameter for the gap. Slice the tubing so you have a c-shape and then press the tubing onto the edge of the car part.
Old 04-27-2009, 02:11 PM   #2 (permalink)
Going from a gap to a bump- is that tested?
Old 04-27-2009, 03:01 PM   #3 (permalink)
zman's Avatar
I realize that optimal surface would be smooth and free of either gaps or bumps, but since air naturally "sticks" to a surface a gap is more disruptive to airflow than a oval shape bump. Both the bump and the gap will produce a wake, but a bump brings the surface closer to being areodynamically correct.
Old 04-27-2009, 04:06 PM   #4 (permalink)
Could just use the neoprene as a strip and slide it into the gap itself and mount it to the car chassis instead of the door. Instead of cutting it in half cut it into like thirds and put that in there. Or just get weather stripping from Home depot or lowes and slap that in there.
Old 04-27-2009, 04:17 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Hello -
Each situation is different. I put some weather stripping on the back of my front driver door as an experiment. I wanted to exploit the "concave" shape of the door to reduce the chance of the strip peeling off. Bad move. You could open the rear driver door, but there was always rubbing on the strip, and eventually it got all messed up, so I took it off. If I do it again, I will put it on the front of the rear driver door.
There's also lots of other weather stripping. It doesn't have to be C-shaped. It can be L-shaped for less or no "bump".
CarloSW2
American Solar Energy Society
Old 04-27-2009, 07:36 PM   #6 (permalink)
Then turbulator tapes don't work?
GTI seat in my Geo and more wt reduction ATaylorRacing EcoModding Central 3 03-15-2009 11:52 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 10:45 PM
How expensive would gas need to be for you to make a 20% reduction in use? SVOboy General Efficiency Discussion 9 01-06-2008 08:29 AM
