Old 08-07-2019, 04:57 AM   #1 (permalink)
just joined..
Civic - '15 Honda Civic Tourer SR
rear wheels - spats or wheel covers?
Any research anyone can share on this?
looking to improve the cars aero, either going to go with rear wheel spats (close the arch) or flat wheel covers.
Anyone got any idea which would be better option?
TIA
Old 08-07-2019, 02:50 PM   #2 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
there is plenty of posts and threads discussing this either on wiki or in forum/aerodynamics. You will find them under the term "wheel skirts" or "fender skirts". It is US forum, after all.
My personal view is this: smooth hubcaps are less effective, but less intrusive and far less noticeable than fender covers. After many curious looks and few pull-ups by local police I dismantled them. In law-bound Europe it is not worth to use them. Otoh, smooth hubcaps are on the safe šíře
Last edited by seifrob; 08-09-2019 at 12:55 PM.. Reason: deleted repeates and typos.
The Following User Says Thank You to seifrob For This Useful Post:
rob.e (08-07-2019)
Old 08-08-2019, 01:23 AM   #3 (permalink)
Agreed that search is your friend. But if you follow it long enough you'll find Morelli's [European] Punto:
https://ecomodder.com/forum/showthre...ail-33283.html
Here you have an axial fan in the rear wheels that feeds a duct into the spat area behind the wheels. That's the black part in the lower corners, separate from the boxed cavity with perforated annular screen.
The title could have been spats, wheel covers, skirts or air curtains. Your answers should be saying it's vehicle and use case specific. So, that.
aerohead (08-10-2019)
Old 08-09-2019, 01:15 PM   #4 (permalink)
Permanent Lurker
seifrob's Avatar
I am pretty sure you found this: https://ecomodder.com/wiki/Car_MPG_E...fications_Main
There is written both mods are worth about 3% MPG. As you drive Civic, which is very clean car aerodynamically, there is not much to be done. go for smooth covers, than grille block. both can be made stealth and are not too demanding on fabrication skills.
The Following 2 Users Say Thank You to seifrob For This Useful Post:
aerohead (08-10-2019), rob.e (08-10-2019)
