Old 10-13-2010, 06:50 PM   #11 (permalink)
improvement
Originally Posted by miket View Post
Aluminum streamline tubing would be ideal but would cost $100+? How much aero improvement would I get for that?
Ladder are lifted from the sides or slid up from behind. I suppose the rearmost fairing could be made of a ridgid and weak material if it was attached on the bottom to a spring so it could bend slide or twist downward from that rack during loading.
The square tubing has Cd 1.15
The streamline tubing has Cd 0.06
Old 10-13-2010, 07:11 PM   #12 (permalink)
I meant would it be worth it in $ per cdA reduction? However a Polyethlene foam fairing might provide the same benefit without the cost.
Simple Honda VX Alloy Wheel Covers (drilled acorn wheel nuts as attachment points) NachtRitter DIY / How-to 53 06-03-2012 09:07 PM
Vibe/Matrix owners that have deleted roof racks... TomO Aerodynamics 0 09-25-2009 01:57 PM
Need a ladder rack - help me pick the best (least worst) option. smatthew Aerodynamics 4 08-15-2009 05:16 PM
