Old 03-08-2013, 03:48 AM   #11 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Originally Posted by H-Man View Post
I can't find any way to tune a Toyota ECU so I can't test anything on the EFI side. Since my car has a manual transmission there isn't much to tune any way, I'm hesitant to mess with air fuel ratios since I would rather not burn out both of my 3-way catalyst converters with an over lean mixture.
You can always use something like Megasquirt MegaSquirt - Electronic Fuel Injection Computer by Bowling and Grippo ©2010 to have full control over injection and ignition process.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 03-09-2013, 05:30 AM   #12 (permalink)
Those aftermarket ECMs are usually good options to overcome the limitations of a stock ECM in an ecomodding project. And they're not so expensive at all, and some have an easy tuning interface.
Old 03-09-2013, 03:00 PM   #13 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
I don't want to mess with those systems since it isn't perfectly legal to do that and all of this will be going into a report.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
Old 03-10-2013, 09:14 PM   #14 (permalink)
Reprogramming the ECM or replacing it with an aftermarket one such as a Megasquirt is not illegal, not even in California.
