Dual OEM AC EV motors, one drive?
Hello all,
Been keeping up with the development of MPaulHolmes' "Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control" and the gears are spinning merrily in my head. I'm still a ways off from being able to afford a conversion, but using 1 or more Nissan Leaf motors with this 200kW capable controller looks like a winner from a bang for the buck perspective. I have what may be a motor or controller theory question, and please keep in mind that I'm a Mechanical Engineer, not an EE. I would like to run two Leaf motors off one controller, based on my assumption that it doesn't seem likely that the Leaf motor is overbuilt enough to put out much more than 100kW without increasing the voltage above a stock Leaf battery pack level, due to hitting the current saturation limit (or something). A single motor is "enough" (80kW constant rating at 7000RPM will theoretically push my theoretical EV up a 6% grade at 60-70mph), but I want more, of course. If a single leaf motor can handle 200kw short term (or longer with additional cooling), then no need to pair up. Theoretically, this can be done - at least, it is common in industry to run multiple AC motors off a single VFD. However, the Leaf is an Interior Permanent Magnet type AC motor, thus if I understand correctly it is a synchronous type and operates without "slip", and this complicates the process of trying to parallel two motors. I have an idea of what I would need to do to make two IPM motors work on one drive, so please follow along and let me know where I made my mistakes, and correct them if possible. Poking around on the web I found some quite good cutaway views of the Leaf driveline, one included a teardown of the motor itself, showing that the rotor lamination stack is keyed to the main shaft (more like two very long slots on the shaft, 180 degrees apart, and the laminations have an integral pair of tabs that fit into said slots). Thus one could "easily" make a longer shaft and press two rotor lamination stacks onto it, and expect them to be very well aligned. The stator windings/lamination stack is press-fit into the cooling-channel equipped main motor housing - it is unclear whether there is any keying there. The "simplest" way to pair them up would be to machine an adapter that would connect the "front" of one stator housing to the "back" of the next housing, with the stator slots aligned. Obviously the stator spacing would need to match the spacing of the rotors on the new common shaft. Re-assemble, and you have a double-length motor with two rotors on one shaft, two stators in paired housings, each with their own cooling jacket and stator wiring connections, and one can use a factory front and rear housing end-plate and bearing setup on the ends. Custom work can be done to add additional cooling to the end-turns if desired. Is this sufficient to align the two motors well enough to achieve proper operation when the stators are connected in parallel to the controller, or do I need to set up my "stator housing coupler" to be adjustable and play with the alignment until I get some measurable electrical output from the two stator windings to match? If I need to play with it, what sort of electrical output do I look for? I thought I could set it up and spin the rotor and watch the AC waveforms from the two stators on a scope and adjust the two housings relative to each other until they match as closely as possible. Or, I could run the paired motors off the controller at a low current and adjust the relative position of the stators until max torque is reached - but this is a much harder setup. On the electrical side of things, once the two motors are aligned, do I just hook up the two stators in parallel - making sure the correct phases are connected so the unit doesn't fight itself? Do I need to carefully adjust the wiring resistance so they are equal, or is inductance more important, or both? How critical is this adjustment? I would then use only one encoder/resolver for the paired motor. Thoughts? This seemed more straightforward than a custom gearbox to accept two Leaf motors and combine the output into a single output shaft - trying to align the two rotors through the gears adds the problem of slop and having to re-do it every time you pull a motor or strip a gear. Alternately, if the two motors cannot be paralleled on the same drive for electrical reasons, can the twinned motors be run from a pair of inverters in master-slave mode, assuming the motors are aligned well enough that the single resolver is accurate enough to provide rotor position information for both motors? How about if two standalone motor/encoder/inverter sets are mechanically connected? What would be awesome is a way to run two stock Leaf inverters this way... Note that both ideas can be extended to pair up two or more of virtually any available wrecked OEM EV motors and possibly their inverters, depending on motor mechanical setup and inverter electronics/control scheme. Thanks! |
http://techon.nikkeibp.co.jp/english...4/193591/2.JPG
http://techon.nikkeibp.co.jp/english/NEWS_EN/20110724/193591/?SS=imgview_e&FD=47620101 The other thread you might look at is Hot-rodding the Toyota MGR. The OP, e*clipse, is working on combining two of the MGR in a custom case. It's rotor splines onto the shaft. He might be interested in or have answers to your questions. Arcimoto use two electric motors in front-wheel drive. It's not clear to me if there is a differential or the controller[s] provide the differential action, driving each wheel separately. To what will you custom shaft connect. IOW base vehicle, front or rear drive, lateral or longitudinal, etc. Have you considered putting one MGR on each end of the car for 4WD? |
Hello freebeard,
I've been keeping up with that thread as well. Intended application is an old 4x4 FJ-40 Toyota Land Cruiser. If axle-mounted motors get a sufficient torque/speed spread without having to change gears by the time my budget is available, I could go 1 motor per end or per wheel, but at this time it is far simpler to run everything through the transfercase and driveshafts to the existing front/rear live axle setup. For off-road application, the setup to meet or exceed is ~6500 ft-lbs at the axle (with locking diffs, that can be all at one wheel, or divided amongst all 4, depending on how many are in the air/on a slippery surface) in low range. (250 ft-lb gas engine, 3.555:1 first gear, 1.96:1 low range, 3.73:1 axle gearing - total of ~26:1 gearing). Gearing lower (which is cheap down to about 66.5:1) becomes less important so long as sufficient torque is available. Gas engines need gearing to keep enough torque available at slow speeds without stalling the engine or burning up the clutch or torque converter. With insufficient gearing, you end up going too fast sometimes, which means more things busted/broken/bent. With an electric motor being a "constant torque" source below a certain RPM, stalling isn't an issue. For on-road application, acceleration "feel" must meet or exceed the stock 125hp/250 ft-lb gas engine with 4-speed truck-type manual trans and average-ability driver. Pretty low bar to clear. If it isn't fun, it isn't worth it. Self-contained range requirements are low - a stock used (cold-climate, so 9-10 bars showing on the battery still) 2011 Leaf exceeds my needs at present, even in winter. I'll figure out how to get it to remote off-road locations and how to recharge it there later. It'll be a fun commuter first. |
Congrats on having an FJ-40. I have some friends that keep saying they're finally going to sell the family Scout II.
You may be able to extrapolate from putting an AC motor on a VW transaxle. First gear is useless. Second is a good low end, for pickup. You can drive in 3rd all day if you don't mind oozing away from stop signs. 4th is like an overdrive, but the motor hits the knee in the torque curve and chokes. I'm no help at all when it comes to machining shafts and adapter plates. |
To my knowledge (please - I`d love to be wrong on this one!) no one does sensored or sensorless vector control, Field Oriented Control, etc with more than one motor per controller. Quote:
So making both motors put out full torque with the same signal when they are coupled is quite a challenge. I won`t say impossible .. but I will say much more math to prove one way or the other than I`m up for! Quote:
Hello again freebeard and thingstodo,
freebeard, I currently don't have an FJ40 - haven't for over a decade. See, I had one as my first and second vehicles (rolled the first one, put over 100K miles on the second) and then mostly parked it after graduating from University and needing to work. Eventually I moved, and took it with me, and by then it needed more than just some repair. So I took it apart to "restore" it but had no money, so it got piled up in the back yard and sat for ~7 years, and then I sold it and started a family and all that. I want back in, but I DO NOT WANT the ~12mpg mine had or the ~20mpg a diesel would get. A diesel conversion done right would likely be close to the cost of an AC EV conversion, if I can use junkyard OEM EV parts. Plus I want to be different. :-) Scouts are cool, too, but also suffer from Demon Rust - and I imprinted on FJ-40's, so they're not really what I want. if one has the cash, fiberglass body parts are available for both, and Aluminum for the 'Cruiser. As for how the AC motor feels through a transaxle, that is good to know. Do you have an HPEV's AC setup? When you mention the torque hitting the knee and the motor choking, I recall from the peak power graphs for their motors that HP does actually peak on those, with the downslope almost as steep as the upslope, whereas on the OEM EV motors I'm thinking of (Leaf, Volt, etc.) they do a flat constant power region after the flat constant torque region. Should help some. There'll be a point at which it makes sense to shift up after the torque falls off too much, but it'll be a wider spread. I want liquid-cooled AC so I can sit there "stalled" on a rock without burning it up, and if it can keep liquid in I can seal it well enough for a dunking. Air-cooled brushed DC would be relatively easy/cheap, but keeping water out is much more of a challenge. thingstodo, thanks for the insights! For aligning the two motors, I considered the rotors aligned by way of their built-in keys good enough, with the rest of the work being in aligning the two stators. As for possibility, AMR appears to sell "dual core" motors with single inverters, and IIRC those are IPM type REMY motor cores. No idea of the math needed, though! Sounds like trying to run two IPM or SPM or similar motors off the same drive may not be worth the hassle. How much less critical is it to get two stator windings for induction machines equal in terms of resistance/inductance when running them in parallel off the same drive? You said it is possible to run two OEM AC motor/drive combos in master/slave mode on a common (or geared/belted together) shaft. Any ideas as to how to control those drives? Mostly thinking OEM EV drives here - for common junkyard availability. For the aftermarket Curtis controllers, and many common industrial VFD's, they have that feature built in - just connect them up and put in the right settings. Not sure that is the case for OEM EV drives - and it seems like it would be an extra-cost thing that wouldn't be worth it to the OEMs to implement. Hmm. I guess I could send the throttle signal to a separate "controller controller" and have it divvy up the torque demand to the two OEM drives, possibly with a current sensor on a phase of each motor to have a feedback for how well balanced the setup is running, if needed. Or just twin the throttle output and send it to both controllers at the same time, maybe monitor the current on/temperature of each motor for a while in early days to check the balance and see if it needs adjusting. I've got lots of time to plan this out as the budget builds all too slowly. I'll probably end up buying a used Leaf to replace my currently dissolving ICE car as a commuter (different budget - I need to commute, after all!) for my first EV, as my toy budget may get big enough to buy a running/driving FJ-40 before it gets big enough to buy enough good parts to build one plus the EV bits. Thanks! |
*WARNING * another long-winded post!
I don`t know of any research on-going at the moment to drive multiple motors of any type in Field Oriented Control or sensorless vector. If the nerds are not arguing about it - there must be an obvious problem or two. Quote:
With a modern dual-signal hall effect sensor, you could .. in theory .. send the same throttle signal to each controller. The controllers *COULD* fight if one of them saw the signal as slight regenerative braking while the other saw the signal as slight acceleration .. but the calibration curves for the throttle should take care of that. There`s always a bit of deadband around `coast`. That should take care of it. Quote:
Going back to a Jack Rickard (EVTV) video - you would need some sort of limited slip arbitration, or ABS maybe, so that you do not break loose one rear tire while accelerating through a turn. Quote:
Making things work with OEM parts has some advantages: - if you sell it eventually, the new owner can find parts and has confidence that he can - you can go and buy a part off the shelf to get back running ... if you need to .. or you can get another wreck or buy something from a wrecker - Comparatively little issues with `that company is out of business, or the part is obsolete so you can`t fix it`. The alternative, for me, is Open Source. I`m not dedicated to building the boards, or soldering, or writing the program myself. But if you have the schematics you can troubleshoot it yourself. If you locate something that died - like an IGBT - you can buy a replacement and put it in, or get someone at a maker space to put it in. You have the power! The software may not be as bullet-proof as an off-the-shelf product .. but it may be better .. depending on the guys doing the open source. If you see some new feature in a car in 2 years .. and you want it badly enough .. you can add it! Boy - I do rant on, don`t I? I will follow your build with interest! |
Hello again thingstodo,
I've seen a few papers out on the 'net, but without the EE background I can't tell what's BS and what's not. Quote:
I'll likely keep asking questions here and there on this forum as I get ideas I want to check. Thanks! |
To get full torque on a 3 phase motor rotor inductance and reactance have to be equal, this usually happens at 20% to 30% rotor to stator magnetic slip speed.
